1 members (JohnMat), 267 guests, and 103 robots.
+8Rich 76
Topics49,869
Posts837,666
Moggo
CBY Offline OP
Test and compare the efficiency of the suspension of your MOG with your other cars by using phyphox on your smartphone in order to measure the acceleration.
What you fill in a vehicule is the acceleration, with constant speed you don't have any feeling, by example in a lift you fill only the start and the the stop.
In order to compare your different cars you must use the same travel and the same speed, vertical acceleration on a bumpy road is linked to the frequency of the oscillations.
This is more secure to let a passenger operate the smartphone.
You can download the data on your PC and draw the curves with EXCEL or LibreOffice.
https://phyphox.org/
Regards
2005 PLUS 4
My bum does that for me wink
I suspect having it documented would leave me dissapointed. Interesting app though.
swmbo is far more sensitive. I don't need the app or Google im married.
+1
Costock, UK
Disco 5
I found Kidney stones were quite tuned in to stiff suspension sick
CBY Offline OP
I like your humour but for a scientist your bum acts like a damper, depending on your weight. This is not the best sensor.
Use your inner ear, it is directly linked to the brain, and avoid long nerve.
Regards
2005 PLUS 4
"and avoid long nerve." is that a euphemism ?
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
A drive in the 4/4 really helps the running total in Mrs E's step counting app.
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
CBY,
Thank you for posting this and make us aware of this tool, at one point in time I will look into this.
Have you used it and are you able to share results?
Thanks,
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
CBY Offline OP
No euphemism, only the distance between 2 points.
Regards
2005 PLUS 4
