1 members (yobtaf),
343
41
Topics49,860
Posts837,486
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Good result Dave  Glad you are fitting the trumpets facing downwards. TBH this was something on your first mounting that grated with me although this is my first mention  Mine are facing forward with no issues, then again avoid wet weather as its no fun. I never bothered with the faffing about with extra wiring with relays etc...i just swapped over plug and play. 3 years with no issues. ![[Linked Image]](https://tm-img.com/images/2023/03/08/C4D50097-74D3-46E8-9C3E-8E3E56CB4C7E.jpeg)
Craig Jezz
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
Why mount anything in front of the radiator which potentially interrupts airflow, there must be space behind the bodywork?
Posts: 1,050 Likes: 150
Posts: 1,050 Likes: 150 |
I have zero concerns with overheating, I run a vinyl number plate on the front wing so no number plate box, and if anything my deeper and far more efficient SiFab aluminium radiator over cools. Anyway, once the air has entered past the grill and is in the void between it and the rad, it only has one place to go. Horns or no horns, all that air has got to pass through the rad  Dave.
Once it enters the grill and is in the void behind it the airflow only has one place to go, horns or no horns it's got to pass through the rad.
Dave. +1 SiFab Aluminium radiator
Craig Jezz
Posts: 792 Likes: 143
Posts: 792 Likes: 143 |
Mounted my twin horns well out of the way behind the radiator on a bracket gismo I fabricated from sheet aluminium and off cuts. ![[Linked Image]](https://tm-img.com/images/2022/07/18/IMG_3021.jpg)
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
^^ Wow, that's a proper bit of bracket engineering Chris !
Thanks Jon 👍
Drill, jig saw, file, energy paper, polish, vice and workbench. Oh and a good few enjoyable hours.
Chris
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Fitted mine behind the grill several years ago no problem with overheating..
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Mounted my twin horns well out of the way behind the radiator on a bracket gismo I fabricated from sheet aluminium and off cuts. ![[Linked Image]](https://tm-img.com/images/2022/07/18/IMG_3021.jpg) Your solution looks very nice. Personally, I am always afraid that aluminium loaded with weight will break due to vibrations.
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
I have only good experiences with aluminum, even with additional weight, on a Harley. And a Dyna without balance shaft has viberationen without end
Clemens
PlusFour Red Baron MY 2022
