4 members (SteveT, Strathaven, cerealsurfer, MartinB60), 250 guests, and 98 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
Good result Dave thumbs Glad you are fitting the trumpets facing downwards. TBH this was something on your first mounting that grated with me although this is my first mention wink
Mine are facing forward with no issues, then again avoid wet weather as its no fun. I never bothered with the faffing about with extra wiring with relays etc...i just swapped over plug and play. 3 years with no issues.
Craig Jezz
Why mount anything in front of the radiator which potentially interrupts airflow, there must be space behind the bodywork?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
I have zero concerns with overheating, I run a vinyl number plate on the front wing so no number plate box, and if anything my deeper and far more efficient SiFab aluminium radiator over cools.
Anyway, once the air has entered past the grill and is in the void between it and the rad, it only has one place to go.
Horns or no horns, all that air has got to pass through the rad winky
Dave.
Once it enters the grill and is in the void behind it the airflow only has one place to go, horns or no horns it's got to pass through the rad.
Dave.
+1 SiFab Aluminium radiator thumbs
Craig Jezz
Mounted my twin horns well out of the way behind the radiator on a bracket gismo I fabricated from sheet aluminium and off cuts.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
^^ Wow, that's a proper bit of bracket engineering Chris !
Thanks Jon 👍
Drill, jig saw, file, energy paper, polish, vice and workbench. Oh and a good few enjoyable hours.
Chris
Black Rat
Black Rat
Fitted mine behind the grill several years ago no problem with overheating..
Keith
2013 narrow bodied + 4 Ruby.
Your solution looks very nice.
Personally, I am always afraid that aluminium loaded with weight will break due to vibrations.
I have only good experiences with aluminum, even with additional weight, on a Harley. And a Dyna without balance shaft has viberationen without end
Clemens
PlusFour Red Baron MY 2022
