7 members (John V6, stumog, Simon, JohnHarris, Grumpy2, JoeSpeetjens, Gramrugby),
319
61
Topics49,859
Posts837,504
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
I went for the Williams holder so that the umbrella is always accessible, I've got quite long legs so my seat is always fully back and if I put the umbrella on the parcel shelf I had to take out the luggage to get to it as it moved about if on top of the Hills Alive cases. I thought about the PVC tube option as it would have been a lot cheaper but I think my pride and joy looks much better with a bit more shiny  . I regularly get asked "what is that?", my favourite response is that it holds the back-up batteries  Here's a pic taken from above, the nut faces the front of the car so isn't very obvious. ![[Linked Image]](https://www.tm-img.com/images/2023/03/09/Umbrella2.md.jpeg)
Steve L.
1996 Plus 8 N22 MOG
How about a few turns of PTFE plumbers tape on the male threads to 'tighten' the cap fit ? The odd thing is that the cap seems very tight (there's an o-ring on it) but they seem to vibrate off quite quickly.
Steve L.
1996 Plus 8 N22 MOG
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
I think the idea sounds good... but I don't really like it. A bit bulky I feel ![[Linked Image]](https://www.tm-img.com/images/2023/03/09/morgan-umbrella-holder-3-1016-p.jpeg)
Clemens
PlusFour Red Baron MY 2022
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
On the shelf behind the seats. Works fine till the Hills Alive luggage is in there. Then it sits on top of the bags, though there is still space behind the bags Mine goes behind the Hills Alive luggage. Yes it does on mine too but then you can't get to it quickly. I have the bags locked to the car via a steel cable so if for example you are caught in a heavy thunder storm on the Naples ring road you can't get it up quickly (ooh matron) & just get soaked putting up the hood. Mind you I find the tube on the rear rack looks v odd.
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I adopted a bespoke approach. I had bumpers on the car originally but I preferred a cleaner look so I combined an umbrella tube with overrider and luggage rack support all in one. Also changed the number plate and reverse / high intensity rear light set up. ![[Linked Image]](https://tm-img.com/images/2023/03/09/IMG_2254.jpeg)
Bob
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
I thought about the PVC tube option as it would have been a lot cheaper but I think my pride and joy looks much better with a bit more shiny  . I regularly get asked "what is that?", my favourite response is that it holds the back-up batteries  When I am asked what it is I tell them it is the "Anti Porsche Rocket Launcher"
I adopted a bespoke approach. I had bumpers on the car originally but I preferred a cleaner look so I combined an umbrella tube with overrider and luggage rack support all in one. Also changed the number plate and reverse / high intensity rear light set up. ![[Linked Image]](https://tm-img.com/images/2023/03/09/IMG_2254.jpeg) Very clever Bob, I think that looks very smart.
Steve L.
1996 Plus 8 N22 MOG
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Have you still got a rear foglight somewhere?
Yes Nick, I used dual colour LEDs wired so that both come on white as reversing lights or red as high intensity fog lights.
Thankfully, I've never needed to use reverse and fog lights at the same time.
Bob
Thankfully, I've never needed to use reverse and fog lights at the same time. Neat. Yes, please don't drive backwards in fog!
