8 members (Morganmike, nick w, Graham, G4FUJ, MOGDave, Hamwich, uvk33n, AlyMatt, Deejay),
241
Topics49,914
Posts838,190
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
Thanks! I'd like to say it was easy, but it was far from it. I think the order is the key. And getting the nuts on the U-bolts is good to do while there is still plenty of room. Finish tightening them when everything else is complete.
One question I have, I've read that I should torque the U-bolts nuts to 30 ft lbs. I only have a conventional torque wrench that I would normally put a socket on, but that won't fit between the chassis and the springs. Any suggestions? I used a normal spanner, and did them up 'tight'. After a couple of weeks I checked them all over and gave them another tweak.
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
One question I have, I've read that I should torque the U-bolts nuts to 30 ft lbs. I only have a conventional torque wrench that I would normally put a socket on, but that won't fit between the chassis and the springs. Any suggestions? I used a normal spanner, and did them up 'tight'. After a couple of weeks I checked them all over and gave them another tweak. That's what I did.
Posts: 810 Likes: 59
Posts: 810 Likes: 59 |
One question I have, I've read that I should torque the U-bolts nuts to 30 ft lbs. I only have a conventional torque wrench that I would normally put a socket on, but that won't fit between the chassis and the springs. Any suggestions? I used a normal spanner, and did them up 'tight'. After a couple of weeks I checked them all over and gave them another tweak. That's what I did. Thanks, boys. That sounds like what I'll do too!
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
Changed engine oil and filter, also changed the gearbox oil for Redline MTL (moss box). Well, correction, I took the Morgan to my local independent for the oil change. I am a bit too long in the tooth to get under the car to drain the oils, even using ramps. The days of crawling under cars changing clutches etc have, unfortunately long gone.
1956 Plus 4 4 seater
Posts: 28,913 Likes: 354
Posts: 28,913 Likes: 354 |
The days of crawling under cars changing clutches etc have, unfortunately long gone. I know the feeling!
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
The days of crawling under cars changing clutches etc have, unfortunately long gone. I know the feeling!  I have trouble putting my socks on these days.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
As I got older, occasional vertigo was my main problem under the car, but the Epley manoeuvre is surprisingly effective at repositioning those pesky inner ear crystals.
Other than that, I'm just careful with what I lift. It's very easy to pull something unexpected!!
One day I'll give up, but that day is not today!
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
I'm just careful with what I lift. It's very easy to pull something unexpected!! ...reminds me of when I was a student, I had to be careful what I drank, as it's very easy to pull something unexpected!
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Beer goggles are dangerous.
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Changed engine oil and filter, also changed the gearbox oil for Redline MTL (moss box). Well, correction, I took the Morgan to my local independent for the oil change. I am a bit too long in the tooth to get under the car to drain the oils, even using ramps. The days of crawling under cars changing clutches etc have, unfortunately long gone. I'm lucky that our car has a Ford Kent 1600 with the oil drain plug easily accessible under the bonnet, and the filter is just a short reach under the front bumper. I found a drain pan that fits under the car, so I can change the oil and filter with the car on the ground...
