1 members (JohnHarris), 234 guests, and 35 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
#772330 23/03/23 10:53 AM
Hi,
my 1981 4/4 original speedometer remains dark when I turn on the lights. Probably the bulb fused.
Does anyone know if it is possible to change the bulb without removing the instrument from the dashboard?
Thanks
Bert
Bert Wiegand #772357 23/03/23 01:55 PM
Can you get on your back with a powerful torch and check if you can see Speedo housing from under dash? If so a good chance you can pull out the push in bulb holder and replace bulb.
Bert Wiegand #772361 23/03/23 02:19 PM
If RichardV6's suggestion doesn't work, then why not take out the dashboard ? Not a horrible job (mind you, mine is a later car so may differ), and a one-person job. It helps to remove the steering wheel, then after removing the screws that hold the dash in place, the dash can be lowered enough to see behind. Use the opportunity to vacuum-out the bugs and tidy-up the wiring if needed. Disconnect the battery first if you don't want to risk knowing what burning ash smells like.
Bert Wiegand #772363 23/03/23 02:35 PM
Sit in the drivers seat lean forward and put your hand up under the dashboard, if you can reach behind the speedometer then you should be able to pull out the the bulb holder. If you can't get to the back of the speedometer then you know you have to take the dash off.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Bert Wiegand #772367 23/03/23 02:45 PM
As said reach behind the dash. The dash doesn't need to come off if that doesn't work.,you will two knurled nuts that hold the speedo to the dash by a u frame. Undo them and it should push forward.
I always managed by the hand round the back routine.
britmog #772378 23/03/23 03:40 PM
Just don't get carried-away like the owner of this TVR........
Bert Wiegand #772409 23/03/23 05:56 PM
thats how TVRs left the factory.
David Byrne
B3MOG #772410 23/03/23 06:01 PM
laugh2 laugh2 (and that's from a previous owner of many TVRs myself....)
John V6 #772420 23/03/23 06:45 PM
Black Rat
Black Rat
TMI ! laugh2 laugh2 laugh2
Keith
2013 narrow bodied + 4 Ruby.
Bert Wiegand #772432 23/03/23 07:37 PM
Ooh Matron.
