1 members (+8Rich),
313
86
Topics49,870
Posts837,667
Posts: 37 |
Hi All, another question from this newbie! Our 2004 plus 8 has got a 12v socket in the glovebox, I'm wanting to replace this for a usb socket and possibly also fit a tracker while I've got access.
I'm guessing that the 12v socket will have a threaded nut behind the glovebox to hold it in place, how easy/hard is it to access the back of the glovebox?
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Access to the rear of the whole dashboard in one of the easier jobs on a Morgan.
First drop down the steering column to its lowest setting
Then take out the two wood screws, one each side of the dashboard at the lower corners.
The whole dashboard will then come towards you in the car. Most of what lies behind is now accessible.
Only a few tips , try not to leave the dash supported only by electrical cables or you risk later connection problems, give the earths a good tighten up while you are in there, lastly label the relays which are mounted on the wooden bulkhead (it will save you lots of time later) Sorry I can't remember offhand which is which but there are 4 in total (unless someone has added additional items post delivery)
This should give you all the access you need to the back of the glovebox.
That socket was designed (and fused?) for a trickle charger, if you are planning to run any high current items you might need to think about the fuse value.
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Whilst some do you use cigar lighter sockets for charging it's not a good choice and was certainly not designed for such. It's all in the name but over the years became (sadly) accepted as a power source for accessories. The lack of positive security and spring loaded point contact for centre pin do not make for an ideal connection. MMC's current face down location does nothing to improve these facts with a good jolt often parting plug from socket.
Hella/DIN sockets are however designed to power accessories, have a positive pin location and higher current rating. Once you have such there are adaptors available (eBay) to give a couple of USB outlets.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Just pull off the connector and put the USB one where you want it. I fixed mine to the roll over bar but you might not have one.
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
just get a plug in usb socket...mine has two usb sockets...
Richard S 1993 4/4 1966 VeloSolex
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Please note that most USB sockets also consume power when nothing is plugged in.
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
Please note that most USB sockets also consume power when nothing is plugged in. That's why mine are powered from an ignition switched circuit (I used the radio feed since I don't have a radio).
