10 members (Luddite, Stevo666, Plus Four Guy, Image, sewin, Happy super 3, Richardllll, John Winn, DaveW, cerealsurfer),
211
71
Topics49,883
Posts837,821
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
On my LHD Plus 4, 2005 under the aluminium box. I want to fix a tool roll onto it which will involve rivets/screws but can't work out what lies beneath (above the passenger footwell) ![[Linked Image]](https://www.tm-img.com/images/2023/03/29/49739E56-EEDB-44DA-9317-89DC50779630_1_102_o.jpeg)
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Those 2 screws look like the security screws to retain the back of the ECU enclosure. Watch where you drill….
Roger 2011 Plus 4
Posts: 1,405 Likes: 259
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,405 Likes: 259 |
Velcro. heavy duty. I've been thinking about doing something similar.
Posts: 6,672 Likes: 439
Posts: 6,672 Likes: 439 |
It's the passenger footwell. Stick your head under and you should be able to see.
Posts: 185 Likes: 2
It's the passenger footwell. Stick your head under and you should be able to see. No can do at present as I'm rather incapacitated with a broken leg/ankle!!
It's the passenger footwell. Stick your head under and you should be able to see. No can do at present as I'm rather incapacitated with a broken leg/ankle!! Ah. Is there anyone who can stick a camera under and take a few snaps? Least you'd get an idea of spacing/size.
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
Velcro. heavy duty. I've been thinking about doing something similar. Whenever I have bought Shell engine oil from Opie Oils, it has come with a free grey zip up pouch about 10 inches long,, which has two strips of velcro already sewn to the back. I keep in it: cable ties, tape, wire, pliers, adjustable wrench, a couple of screwdrivers, spare relay plus other oddments. I stuck two strips of velcro onto the top of the footwell under the bonnet and it has stayed there with no issues.Better than drilling holes and no chance of water ingress.
Posts: 27,825 Likes: 753
Posts: 27,825 Likes: 753 |
BHM has a parts catalogue here. There is a pre 2005 catalogue. That should show you. But please get someone to take a look or use a camera. In my 2014 roadster that area has fuses relays etc.
Those 2 screws look like the security screws to retain the back of the ECU enclosure. Watch where you drill….  My ecu sat about 15mm below the under surface but there is also a connector and loom towards the front. ![[Linked Image]](https://dl.dropboxusercontent.com/s/prrfe05qdpmp5hx/ecu%20enclosure.jpg) Ps -You won’t be able see from the underside the unless sheet rubber cover is removed, awkward....
Roger 2011 Plus 4
Posts: 8,690 Likes: 497
Posts: 8,690 Likes: 497 |
On my LHD Plus 4, 2005 under the aluminium box. I want to fix a tool roll onto it which will involve rivets/screws but can't work out what lies beneath (above the passenger footwell) ![[Linked Image]](https://www.tm-img.com/images/2023/03/29/49739E56-EEDB-44DA-9317-89DC50779630_1_102_o.jpeg) On my previous Roadster I had the same layout, I bought the newer fusebox that sits there on later Mogs and usually houses all the banks of fuses, ECU and relays, when empty this gives loads of easily accessible storage for tools & spares (sorry don't have photo) whatever you fit just drill UP from below
