10 members (Luddite, Stevo666, Plus Four Guy, Image, sewin, Happy super 3, Richardllll, John Winn, DaveW, cerealsurfer),
211
71
Topics49,883
Posts837,821
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Good evening. I have a pair of rear Avo (New Elms) shocks. With regard to the adjustment, I assume “-“ is soft??
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 8,690 Likes: 497
Posts: 8,690 Likes: 497 |
Anticlockwise on the adjuster opens the internal valve = softer
Posts: 185 Likes: 2
Anticlockwise on the adjuster opens the internal valve = softer Thanks
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Another little tip. if you set the dampers to full hardness, so clockwise to stop, and count the number of clicks...if you then set them counterclockwise on both sides the same number of clicks back to your desired setting, then the result will be more equal than if you start from soft to set clockwise. i hope that makes sense.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
With rear shocks you will probably want them on their softest setting, unless you are doing track time. Another thing with the AVOs is that they have tabs inside that when the shock takes a good thump they bend and lock the shock at whatever setting is on. You can adjust to your hearts content after that but with no change to the shock, so test drive on a pothole free road.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
My rear AVOs are set on 6 clicks up from soft.
