5 members (tezzer, TBM, cerealsurfer, jbk, Cerberas), 130 guests, and 50 robots.
+8Rich 70
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,883
Posts837,822
Gyp
#774423 11/04/23 12:46 PM
I have a 2005 Duratec Plus 4. I am replacing the horrible plastic expansion tank with this Mulfab item but it has one extra exit pipe (circled). Where does it have to go please?
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
I am not familiar with the particular tank but looking at the position of that take -off I would expect it to simply connect to an overflow pipe exiting to the atmosphere.
This tank has a conventional pressure cap unlike the original which I would suspect is a modern plastic system with a tiny hole in the plastic cap for venting.
With the conventional spring loaded cap, there is no breather hole in the cap itself, as the sealing washer simply lifts under pressure to a point where it exposes that take off pipe for venting.
Think I would take advice as to what pressure cap is applicable. (unless of course this tank is specified for your particular model)
Think the plastic caps let go at about 21psi.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Originally Posted by Deejay
I am not familiar with the particular tank but looking at the position of that take -off I would expect it to simply connect to an overflow pipe exiting to the atmosphere. This tank has a conventional pressure cap unlike the original which I would suspect is a modern plastic sealed system. Think I would take advice as to what pressure cap is applicable. (unless of course this tank is specified for your particular model)
I believe so as I gave Mulfab my car details.
2005 Plus 4
2020 Hyundai eKona
just modified my original explanation to make it clearer.
Doug
1958 Triton 650
I think that is an overflow. The plastic ford unit just vents to atmosphere. Run a pipe down to under the car to divert any blow off.
Agreed, it's the pressure cap release overflow. Just route the end of pipe connected to it to a suitable low point. There should rarely be anything come out if the pressure cap is correct.
Assuming you don't overfill when cold
The tube runs into the driver's footwell 6 inches above the accelerator pedal. That way you get an immediate warning if the engine overheats laugh
Makes going for a “burn up”, a whole new proposition?
Doug
1958 Triton 650
doh
