Topics49,838
Posts837,294
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
I would drain it all down and replace it with water less coolant from Evans. You have to use a Prep fluid first, this I believe can be used again on other engines. But once you use the Evans, it last the life time of the engine. It might be idea to repace the pipework if required. I have no connection with the company, just very happy with it. Look at https://evanscoolant.co.uk for more info. And here’s a 30-page thread that started off with waterless coolant…. http://www.talkmorgan.com/ubbthreads.php/topics/335878/1  Ken was a legend with a great sense of fun once he realised what company he was keeping - this thread has yet to be surpassed - pity he sold the car
Posts: 919 Likes: 47
Posts: 919 Likes: 47 |
WARNING
The goal of having an elaborate vehicle cooling system in which we pump a liquid we call "coolant" through a vehicle engine is (duh!) to COOLTHE ENGINE. Engines have been exhaustively (pun!) tested by the manufacturers within a tight range. Below a certain minimum, they run too cool, inefficiently, with bad mileage and get badly gummed up inside. They innards are a mess...seen that many times. Above a certain maximum temperature for too long a time, they blow gaskets, twist heads and boil over. Boiling over is the surest symptom that something is amiss in this area..or has already caused the damage indicated. Why eliminate key symptoms of pending engine damage. ?
The goal of Evans Coolant is merely not to boil over, which is not a primary goal that any car manufacturer ever thought of. Yet for some reason, (better marketing?) this stuff caught on more deeply in the UK than in the USA, where it is made! Was that caused by boiling over in a cooler climate....more bumper to bumper traffic? I drove a very muscly Morgan, a model historically infamous for overheating, for 11 years in the UK/Europe. Never boiled over, except once, after I blew my head gaskets with my earlier, smaller engine. I have been known to indulge in sporty driving. [BLUSH!]
For American-style autocross, surely the most engine-heating pastime I have ever encountered on two continents, I recommend pure unmixed coolant. John Sheally II, with over 1200 wins sent to Peter Morgan, used it. Also much cheaper. But for a road-going engine, find a water based brew and cooling system and tuning that keeps your engine within that magic range.
If there are those of you who like cons along with data:
https://www.gomog.com/allmorgan/coolantcolors.html#WATERLESS#CONS
