8 members (Gonze, JohnHarris, GrumpyPa, RichardV6, +8Rich, John V6, IcePack, Chris Cosher),
211
38
Topics49,904
Posts838,094
Posts: 875 Likes: 157
Posts: 875 Likes: 157 |
several accessories were delivered with the Morgan Roadster that I bought this week. I can ride with the Easy fit soft top I can ride with the tonneau cover But I also have in the kit 2 flexible half-doors which are fixed above the doors of the cars. Have you ever seen this before? If so, what is the use? : ![[Linked Image]](https://zupimages.net/up/23/16/guoa.jpg) ![[Linked Image]](https://zupimages.net/up/23/16/wedp.jpg)
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 101 Likes: 6
Posts: 101 Likes: 6 |
It is a possibility they replace the zipped sections of the three zip tonneau cover. Which is fitted to some Morgans.
Posts: 55 |
There are some Mog owners out here that use them in cold weather to reduce the cold wind coming over the top of the doors when not using the s/screens.
1963 4/4 SER.V. B876 Owned since 1968 -1965 Anglia 124E- sold.
Posts: 8,699 Likes: 416
Posts: 8,699 Likes: 416 |
There are some Mog owners out here that use them in cold weather to reduce the cold wind coming over the top of the doors when not using the s/screens. Never seen them before but Dave's explanation sounds spot on. I imagine windscreen side deflectors would have similar effect in reducing the considerable turbulence you receive with side screens off.
Posts: 3,881 Likes: 402
Posts: 3,881 Likes: 402 |
They probably would also help in the wet with rain spray from other road users
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 27,842 Likes: 764
Posts: 27,842 Likes: 764 |
Just like a 3 zip tonneau
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Indeed, the same effect as a three zipped tonneau, which I used often on my 4/4. I assume this solution means you have several Tenax fasteners extra!?
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
This attaches in the same places as the full tonneau cover : ![[Linked Image]](https://zupimages.net/up/23/17/7vxw.jpg)
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
I've seen the three zip tonneau - aren't they a bit of a pain when you want to get in and out?
Posts: 3,828 Likes: 69
Posts: 3,828 Likes: 69 |
How do those headrests poke through, is there just a hole? Is it rainproof? For my first Morgan I made some half side screens but they were solid so just fitted to the main brackets. I covered them in leatherlike plastic. They were essentially just the lower part of a standard sidescreen, no windows attached. I bound the tops with pipework foam covering wrapped in leathercloth to match the dash. They were ok but I ended up never using them.Lots of work making them but it was fun.
