8 members (Vansrv6, Craig Jezz, vbalddave, bmgermany, cerealsurfer, JMcL, sewin, +8Rich), 109 guests, and 28 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,100
several accessories were delivered with the Morgan Roadster that I bought this week.
I can ride with the Easy fit soft top
I can ride with the tonneau cover
But I also have in the kit 2 flexible half-doors which are fixed above the doors of the cars.
Have you ever seen this before? If so, what is the use? :
Lille - France
Plus Four 2024
It is a possibility they replace the zipped sections of the three zip tonneau cover. Which is fitted to some Morgans.
There are some Mog owners out here that use them in cold weather to reduce the cold wind coming over the top of the doors when not using the s/screens.
1963 4/4 SER.V. B876 Owned since 1968
-1965 Anglia 124E- sold.
Never seen them before but Dave's explanation sounds spot on. I imagine windscreen side deflectors would have similar effect in reducing the considerable turbulence you receive with side screens off.
They probably would also help in the wet with rain spray from other road users
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Just like a 3 zip tonneau
Indeed, the same effect as a three zipped tonneau, which I used often on my 4/4. I assume this solution means you have several Tenax fasteners extra!?
Ruut Bianchi
This attaches in the same places as the full tonneau cover :
Lille - France
Plus Four 2024
TBM Offline
I've seen the three zip tonneau - aren't they a bit of a pain when you want to get in and out?
How do those headrests poke through, is there just a hole? Is it rainproof?
For my first Morgan I made some half side screens but they were solid so just fitted to the main brackets. I covered them in leatherlike plastic. They were essentially just the lower part of a standard sidescreen, no windows attached. I bound the tops with pipework foam covering wrapped in leathercloth to match the dash.
They were ok but I ended up never using them.Lots of work making them but it was fun.
