8 members (JohnHarris, MartO, MATTMOG, Sir Percival, Anonymouse, TalkMorgan, Zach, DickJ),
233
36
Topics49,912
Posts838,164
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
I don't want to give any more tips here on how I would fix it, because very sensible suggestions have been made. Just one point, I would go over the affected area with a bit of polish to more accurately assess the damage. I have a suspicion that not everywhere the paint is gone where it is white, but that there is some white layer from the touch on the paint. That might make the repair area perhaps smaller if it is so.
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
Just my perspective here -- I would never put polish on scraped/bare metal, as (even if it is removed carefully during preparation) it will make it harder for the repair paint to adhere.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
I've had very good results using water based twin pack aerosols, one for flat colour and another for clear laquer. After Googling for source bought the pair colour matched to Morgan paint code and sprayed a number plate box I had shortened to match grill width. Obviously the surface was prepared first and treated to several coats of high build primer with rub down eventually to 1500 grit wet and dry. A few coats of colour then applied followed by a lesser number (maybe just two or three) of the laquer. The results exceeded my expectations with a perfect colour match to existing paint. Given the fact that Clemens damage is on a lower edge I would have no hesitation in making a localised repair myself using same but with thorough preparation and priming first using in this case, high build etching primer.
Posts: 40 |
Last week i did the same just the same wing gate post ime having the paint shop spray the wing up to the paint protection film the car has never been driven in the rain so just planning a dry day to get it done .
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
I have had the color analyzed. The color code for Classic Meteor Red is (CFJ) TG14B. I am now waiting for the mixed colors and then a professional painter will do the repair.
Clemens
PlusFour Red Baron MY 2022
Posts: 37,489 Likes: 993
Posts: 37,489 Likes: 993 |
Good news Clemens you are well on the way now back to perfection.
Was perfectly repaired from a professional painter. Is absolutely nothing more to see. The mood is good again  ![[Linked Image]](https://www.tm-img.com/images/2023/05/04/IMG_0800.jpeg)
Clemens
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
Excellent news Clemens, go and enjoy 👍
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
That looks better than new Clemens and very quick
Posts: 1,876 Likes: 174
Posts: 1,876 Likes: 174 |
Perfect result Clemens, glad for you! And now go on enjoying your beautiful PlusFour!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
