8 members (Bunny, linklaw, Strathaven, Bilymog, Graham, G4FUJ, DavidR, lez, TalkMorgan),
186
35
Topics49,905
Posts838,103
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Got annoyed with myself yesterday. Have me when parking out of the garage the first scratch on the paint pulled. has someone experience with paint touch-up or should I go straight to a painter. Am grateful for any tip ![[Linked Image]](https://tm-img.com/images/2023/04/23/CA87E9BC-60E9-4F9D-B909-744BC42267AC.jpeg)
Clemens
PlusFour Red Baron MY 2022
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
I know how you feel Clemens, my car had almost identical damage caused by the ratchet strap when it came off the trailer. The factory provided the paint code and the local paint shop managed to stop the paint on the edge of the raised area on the arch. Mine is metallic and honestly you cannot see any sign of the repair in any light conditions. So I suggest taking the car to the paint shop. Good luck.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Thanks Gordon for the feedback and the encouraging words ... that makes me already confident that the damage can be repaired again
Clemens
Posts: 502 |
Got annoyed with myself yesterday. Have me when parking out of the garage the first scratch on the paint pulled. has someone experience with paint touch-up or should I go straight to a painter. Am grateful for any tip ![[Linked Image]](https://tm-img.com/images/2023/04/23/CA87E9BC-60E9-4F9D-B909-744BC42267AC.jpeg) Where your damage is, you could just order a touch up pen which also has a little brush inside it, and just paint it over the scrape. On very close inspection you will see it, but I can guarantee, after a while, you'll forget about it, and it won't even register with you. Good that it's not on a flat surface in the middle of a panel that would really stand out.
2004 Series 1 Roadster
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Sorry to hear Clemens. The best solution depends on your character. The location of the scratch and the fact it's a brand new car, I should suggest that because it's fortunately on a perfect spot for spot repair let have it done professionally, won't cost too much, and you can at least forget about it......!! Would be my choice! Good luck with it!👊🙋🏼♂️
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 572 Likes: 93
Posts: 572 Likes: 93 |
Beware using Morgans own touch up paint pens, the one supplied for our Plus Six ( with correct paint code ) was nowhere near the colour. A paint repair specialist made up a touch up pen for us that matchs the cars paint.
Also, having dabbled with a few paint jobs on motorcycles and looking at the size of the scrape and its location, I would suggest a "smart" repair. In the UK there are mobile specialists that will come to your house and repair it on site for not huge money. That scrape could easily be repaired using an airbrush, although its worth noting that if there are any marks into the alloy, then it may need a little body filler first and then an etch primer so that the paint bonds correctly to any exposed alloy. Then the colour coat and clear coat goes on. I am sure it can be fixed to be a invisible repair.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Touch up paint isn‘t a good idea.
Ask for a specialist for „smart repair“. Mustn‘t be your dealer.
Look for good quantity and named bodyshops.
Greets René
Lackstift ist keine gute Idee, auch Sprühdose ist nicht so toll.
Ich hatte ein ähnliches Problem. Am ersten Tag zurück in Deutschland hatte ich massive Kratzer auf dem vorderen Kotflügel. Durch den Selbstimport war das Auto noch in GB versichert und wurde dort repariert.
Es gibt spezielle Betriebe für „Smart repair“. Hier einfach mit der Autowerkstatt deines Alltagsautos fragen mit wem die zusammen arbeiten. Grundsätzlich haben viele Autohäuser deutscher „Premiumhersteller“ eine Kooperation. Der Farbton sollte kein Problem sein, hier wird in der Regel immer eine Farbanalyse gemacht.
Lack ist bei Morgan übrigens ganz normaler wasserbasierter Autolack.
Viel Erfolg und Gruß aus Mainz
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 37,486 Likes: 991
Posts: 37,486 Likes: 991 |
Clemens, really sorry to read this, we have all done it.
Considering the newness and value of your car I definitely think you need to have a professional outfit complete the job for you.
You probably have some very good "at your home" repair outfits in Germany and a recommendation is handy, your local car club will know of someone..
Vielen Dank René. Das mach ich so 👍 Thanks Richard... will visit a professional auto painter 😀
Thank you all ... my mood is already better again 🤗
Clemens
Posts: 2,121 Likes: 71
Posts: 2,121 Likes: 71 |
Clemens
as has been written here several timies: Paint Touch would not be effektive. It looks like the allu at the wing also has some scratches so Best way is to as some paint shops.
I understand your feelings quite well - but there are more expensive mistakes one can make.
I remember that it took me only two days to let my hood scratch my New Morgan Park stearing wheel.
I did see this marks on every trip and when I did not look at tbe scratches I did feel them.....
