2 members (JohnHarris, TalkMorgan), 345 guests, and 96 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Page 2 of 10 1 2 3 4 9 10
Peter, is this the reconquista-mog?
2003 Morgan 4/4 2-seater
Yes but Morgan agreed it was not up to the job and changed it.
An update.
Today after a few weeks and over 500 miles I removed the ali panel to see if the paint was being damaged. Despite fitting a neoprene seal to the edge the panel has left light scratches in the panel.
Luckily these polished out. So time for a rethink as clearly it is either the panel or the spare not both.
John, I suspect that the seal is compressing enough for the internal rolled edge to catch the paintwork
Even with a thicker seal you may still find that fine particles of muck trapped in the seal abrade the finish anyway
That's a bugger John, but it's patina really - that cover looks really good as it keys in so well with the bonnets.
Exactly. I'll keep it & ponder. It will make stunning garage wall art
The answer may be to use a thicket adhesive neoprene strip on the rear panel, then remove it when you fit the spare. It's a faf, but body twist means a spacer between the two panels is the best option to avoid marks.
It could be Dave.
Adhesive p strip around the edge never had a problem ,don’t over tighten .
Peter.
Aero plus8 50th Anniversary.
Thanks . Something to think about
