7 members (+8Rich, GrumpyPa, Ritchie B, Gordon D, Themorganeer, Stevo666, Horror),
241
69
Topics49,861
Posts837,529
Posts: 40 |
Thanks for the info i will have a look in the garage lights off . They must have used it to fill the hole up.
Posts: 8,675 Likes: 411
Posts: 8,675 Likes: 411 |
All car radio's require two fused circuits Bob, one permanently live (fuse 17) for memory. Even MMC accomodate for them  But my radio continued to work with fuse 9 pulled but would not work with fuse 17 pulled suggesting it is only wired via fuse 17. That does seem odd doesn't it Bob. Could it be your particular radio has a switch or jumper option to work with single power feed? Perhaps you could check that radio turns off with ignition. All I can add is that the lash up radio installation by PO of my Land Rover has the two power feeds joined together at radio and fed direct via fused feed from battery. To turn it off I remove the security front panel. Will get around to proper installation one day
