8 members (sewin, Sir Percival, John V6, DavidR, Chris Cosher, Joske Vermeule, Grumpy2, Robbie),
292
43
Posts837,995
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Good recommendation, there’s so often so much negativity it’s great to hear about garages like this
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 129 Likes: 3
Posts: 129 Likes: 3 |
Thanks John but what obvious spares should carry? The usual answer is "A Toyota".
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Posts: 27,836 Likes: 761
Posts: 27,836 Likes: 761 |
I carry basic tools a few screws , nuts & bolts, insulating tape & tape that can seal leaking hoses, spare bulbs , a length of wire, spare fuses, spare relays and one of those batteries that jump start a car & includes a torch.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Basic tools that can be used for minor repairs. Anything major needs the AA. Basic spanners, screwdriver with interchangable bits, cable ties, electrical goody bag ( basic test meter, fuses, wire, tape, bulbs, relays). Couple of smallish ratchet straps for extra luggage securing if needed.or anything else. Glass cleaner and cloths. Gloves, towel, wet wipes, bin bag.Jack and brace as normal. Air pressure gauge, small compressor. Sounds. Lot but fits in out of the way ok. I changed the c##p original wipers to the new ones but carry an old one as emergency spare. New are so much better than the Landy ones.
Posts: 61 Likes: 7
Posts: 61 Likes: 7 |
I’ve got most of the items listed but some good recommendations for additional ‘stuff’. Thanks
4/4 70th Anniversary
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Whenever I am asked what spares do I carry on long distance rallies I reply:
A good working (meaning good service) cell phone, charger, road recovery membership for wherever you are and a credit card that is accepted everywhere. But I also carry what has been listed above along with a quart of oil (for the Moggy not the occupants) and bottles of water to be used by the occupants and the Moggy if needed.
Posts: 61 Likes: 7
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
That link to Amazon takes me to relays rather than fuses!. And the relays shown are not what you need. You need ones with a diode across the relay coil, to protect your ecu against voltage spikes . Better to search ebay for “12volt diode relay” as a greater choice on offer. To distinguish, you will see on the diagram etched onto the relay casing, a diode symbol (like an arrow head with a line across the tip), in parallel with the relay coil.
Posts: 61 Likes: 7
That link to Amazon takes me to relays rather than fuses!. And the relays shown are not what you need. You need ones with a diode across the relay coil, to protect your ecu against voltage spikes . Better to search ebay for “12volt diode relay” as a greater choice on offer. To distinguish, you will see on the diagram etched onto the relay casing, a diode symbol (like an arrow head with a line across the tip), in parallel with the relay coil. Yep I said fuses but meant relays! Thanks for the added detail. I’ve now found these: Bosch 0332209152 Mini Relay 12V 30A, IP5K4, Operating Temperature from -40 Degree to 100 Degree C, 5 Pin Relay with diode https://amzn.eu/d/g2dymNL
