The rear axle was moved forward sometime around 2006, I think when the leaf springs changed from six to four leaves and the Roadster got the single anti tramp bar.
Actually, the rear axle was moved rearward not forward. That sadly made a rear collision disaster
MUCH MORE likely for the 10,000s of trads made before June 1993 if they swap to newer leaf springs. After that
date, the Morgan brakes were changed eliminating
the issue The later 4 leaf springs also centered the
wheels in the rear wells, something some moggers wanted. The risk can be sorted simply and cheaply, but
not all sellers of the newer springs mention it. They should.
BTW,. one can also center the earlier rear axles with an adjustment saddle plate made by
Mulfab.
Once again, aside from a deep friendship with the ex-owner, I have no benefit from this company or any
other I mentionL.
