Topics49,915
Posts838,218
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
New muffler mounts made and installed today. This will hopefully eliminate the rattles in the exhaust system. I didn't get around to installing a flex joint at the header collector this winter, but this should help. ![[Linked Image]](http://tm-img.com/images/2023/05/15/IMG_5861.md.jpeg)
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
Removed enough grass to make a bale of hay from around the rear springs following yesterday's DonMog Grass Autotest.
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
Had the handbrake fail at a red light on a steep hill the other day  Found some time today to investigate, avoiding the gardening!. I found one of the bars that pull on the brakes had broken; ![[Linked Image]](https://tm-img.com/images/2023/05/15/H_BrakeBars.jpeg) My Mog dates from 1956, and I have failed to find any parts for the Girling HN brakes that I think are the ones I have. ![[Linked Image]](https://tm-img.com/images/2022/10/08/IMG_1001.jpg) Hopefully my local indy can weld the broken one, but I shall make a drawing and see if I can find a local company that can make me a couple of new ones. The other one was cracked last year and was welded then. All the info I can find relates to the slightly later HL3 system that came in during 1956
1956 Plus 4 4 seater
Posts: 987 Likes: 110
Posts: 987 Likes: 110 |
It seems that the right one starts to break again, too.
2003 Morgan 4/4 2-seater
Posts: 8,705 Likes: 416
Posts: 8,705 Likes: 416 |
Having fresh ones made is the way to go. Only difficult part for home fabrication is heating to get twist. A blacksmith if you can find one should manage the job.
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
Looking at your picture could you rotate the clevis joint on the bar 90 degrees? Then you could just cut a blank out of a chunk of suitable steel. Fairly easy to fabricate with a grinder and drill.
Post deleted. Posted in error
Posts: 502 |
Fashioned a rubber gasket to put behind the front indicator housing that meets with the bodywork to see if that stops water collecting in the bottom of housing when it rains. Had a good pour down today so will see if it's worked.
2004 Series 1 Roadster
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
Had the handbrake fail at a red light on a steep hill the other day  Found some time today to investigate, avoiding the gardening!. I found one of the bars that pull on the brakes had broken; ![[Linked Image]](https://tm-img.com/images/2023/05/15/H_BrakeBars.jpeg) My Mog dates from 1956, and I have failed to find any parts for the Girling HN brakes that I think are the ones I have. Hopefully my local indy can weld the broken one, but I shall make a drawing and see if I can find a local company that can make me a couple of new ones. The other one was cracked last year and was welded then. All the info I can find relates to the slightly later HL3 system that came in during 1956 You could try these, Paul the owner is very helpful https://www.powertrackbrakes.co.uk/products.html
Thanks, I'll contact them tomorrow.
