8 members (John V6, Pittsartist, JMcL, Jensen1960, JohnHarris, sbarracl, James B W, Haggispeed), 302 guests, and 23 robots.
+8Rich 102
John V6 59
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,179
Georgetoad, woolfie
Page 12 of 173 1 2 10 11 12 13 14 172 173
Glad you got home ok Dave. That top shock nut should be a nylock and tightened down hard against the metal spacers that leave the correct compression on rubber mounts. Even more important to use nylock on lower mounts as the rubbers can be overtightened there.
BTW the allen head at top of shock spindle, or flats in case of adjustable Spax as above, play no part in nut security. They are just there to prevent spindle turning whilst you tighten/loosen nut.
Richard, are you sure you have this the right way round?. From memory, I only recall two thick rubber washers together with “penny washers” on top, but no spacer to tighten up against.. Whereas on the bottom, there is a spacer that you can tighten to. ?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Similar experience Dave when the top shock mount plate broke. Didn't really suspect anything on the 50 mile journey home following a single clunk over severe bump. Fortuitous that greasing was due and noticed the break whilst on the ramp straight after.
A good advert for not using a nylock nut twice maybe although I suspect we all do at least once innocent
The thing is, we discuss the merits of various dampers for Morgans, and yet I've now completed two long journeys with a damper disconnected, and aside from the odd hard bottoming out, you just can't tell.
Can anyone suggest a supplier of bushes for the top of the front dampers please?
grin2
grin2
Wasn't that exactly what Bill Button used to say?
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
grin2
Peter Morgan only had the dampers/shock absorbers fitted because buyers wanted them, other sports cars of the era being fitted with them- he said they weren't necessary/wouldn't make any difference.
06 Saab 93
No it's the other way around Doug with in fact two metal spacers at the top within rubbers each side of mount, which tighten against each other. It's clear in my mind as had to fit new mount plate fairly recently and this has an enlarged hole to accommodate these spacers.
The lower eye mount uses penny washers as well but the stud on stub axle has a larger diameter shoulder to accommodate rubbers directly. I guess you could tighten down hard onto this shoulder but it would force rubber out of eye, hence importance of not overtightening and consequent need for nylock nuts.
I do have Spax gas assisted shocks from SSL kit mind you but don't recall the previous AVO's being any different.
Richard, I'm with Doug on this.
Just checked my old Bilstein and there are no spacers, only rubber bushes.
Also, in the SSL instructions there is a note not to over tighten the top damper nut.
I always thought the top mounts should be left with some flex in them.I.e. "only nipped up and not crushed" (SSL's words, not mine)
Could over tightening cause the top plate problems?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Thanks for that Bob. I was beginning to doubt myself and was looking for the SSL instructions online last night, without success but was fairly sure that was where I saw it written some time ago.
Doug
1958 Triton 650
grin2
Dave, try Dan at SSL
Edit, if you can wait until tomorrow evening, I'll check my store, I'm sure I've got a pair of unused OE shocks
grin2
Thanks Jon, but I've ordered a new pair. I did still have the OE's from the Plus 4 until a few months ago!
For those who want to get the Morgans out next weekend (June 3 & 4, 2023), there's a really big gathering of classic cars near Douai in northern France.
It is in the village of Roost Warendin, in the gardens of The castle of Bernicourt.
Access is free for people who come with classic cars.
There is also a large spare parts market.
It is the club "Les anciennes du ch'ti" (The Oldtimers Of the Mens of North Of France) which organizes each year this pleasant event
The 2022 edition : https://youtu.be/NYaVfYml4Og
Lille - France
Plus Four 2024
