1 members (Montegue), 367 guests, and 47 robots.
+8Rich 93
Posts837,277
Page 58 of 164 1 2 56 57 58 59 60 163 164
A full checkover of the underside after hitting some metal debris the other week, no visible damage but left some nasty witness marks along one silencer (& bust the mudflaps)
All lubed up ready for a tour of North Wales soon
Yesterday, actually, I picked up the new leather gearbox and driveshaft tunnel covers from the upholstery shop.
Very smart
Black Rat
Black Rat
Went to Cain yesterday for a service, right rear brake cylinder seized this is the 3rd one in ten years.
Keith
2013 narrow bodied + 4 Ruby.
You need to peel back the rubber dust covers and wipe plenty of Ceratec around the end of the piston and squeeze a bit into the void as you ping the cover back, that should give a minimum of 10 yrs, if done each year or so
Funny, it’s usually the left hand side that catches all the roadside puddles.
Doug
2011 Plus 4 in Rich Maroon
1972 750 β€œComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I believe that our car has some history of racing because of the engine build, suspension upgrades, fuel cell and evidence that there had been a roll bar installed at some point, but I can not figure out what sanctioning body would allow this fuel fill set-up. The nearly collapsed elbow was barely on the filler neck, the reducer was an exhaust pipe fitting, and the (no longer) flex section was a radiator, not fuel, hose.
All better now thanks to new parts from TANKS Inc.
It's a proper manufactured race fuel cell but presumably fitted by a previous owner ... racers seem to fall into two clans ... the 'obsessively perfect' .. and the 'That'll do' .... guess the PO was the later ... things were a whole lot looser back in the day as regards inspections πŸ™‚
Looking good now though πŸ‘
Nothing overly exciting here, just fitted a pair of A-pillar sidescreen/windscreen rubbers.
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
Thanks! And, yes, the PO who did the work was definitely of the 'That'll do' persuasion. The song "From a Distance" comes to mind...
