2 members (DJC, Socalm3w),
363
Posts837,277
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
A full checkover of the underside after hitting some metal debris the other week, no visible damage but left some nasty witness marks along one silencer (& bust the mudflaps)
All lubed up ready for a tour of North Wales soon
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Yesterday, actually, I picked up the new leather gearbox and driveshaft tunnel covers from the upholstery shop. ![[Linked Image]](http://tm-img.com/images/2023/06/09/IMG_5919.md.jpeg)
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
Went to Cain yesterday for a service, right rear brake cylinder seized this is the 3rd one in ten years.
Went to Cain yesterday for a service, right rear brake cylinder seized this is the 3rd one in ten years. You need to peel back the rubber dust covers and wipe plenty of Ceratec around the end of the piston and squeeze a bit into the void as you ping the cover back, that should give a minimum of 10 yrs, if done each year or so
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Went to Cain yesterday for a service, right rear brake cylinder seized this is the 3rd one in ten years. Funny, itβs usually the left hand side that catches all the roadside puddles.
1972 750 βComDomβ sprinter 1958 Triton 650 1992 Triumph Trophy 900
I believe that our car has some history of racing because of the engine build, suspension upgrades, fuel cell and evidence that there had been a roll bar installed at some point, but I can not figure out what sanctioning body would allow this fuel fill set-up. The nearly collapsed elbow was barely on the filler neck, the reducer was an exhaust pipe fitting, and the (no longer) flex section was a radiator, not fuel, hose. ![[Linked Image]](http://tm-img.com/images/2023/06/11/IMG_5920.md.jpeg) All better now thanks to new parts from TANKS Inc.![[Linked Image]](http://tm-img.com/images/2023/06/11/IMG_5922.md.jpeg)
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
It's a proper manufactured race fuel cell but presumably fitted by a previous owner ... racers seem to fall into two clans ... the 'obsessively perfect' .. and the 'That'll do' .... guess the PO was the later ... things were a whole lot looser back in the day as regards inspections π
Looking good now though π
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Nothing overly exciting here, just fitted a pair of A-pillar sidescreen/windscreen rubbers.
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
K Thanks! And, yes, the PO who did the work was definitely of the 'That'll do' persuasion. The song "From a Distance" comes to mind...
