Posts838,014
Posts: 188 |
My roadster 2004 won't start. what was an occasional issue is now a problem as the dash ignition lights do not come on. On examining the relays behind the dash there appears to be 5 in a group and a sixth that just sits in the wiring loom that i take to be the wipers. My questions are :- what are the five in a line doing? ( I THINK THERE WAS A PREVIOUS THREAD ON THIS TOPIC)there is some corrosion on the lugs of one of them. where can i get replacements as i am not sure if the descriptions on the internet search match those on the relay. I seem to have 4 identical relays with a code 3085 868787a. The fifth one is different.
Electrics isn't my thing so any guidance would be most welcome.
2004 Silver Roadster S1
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
The numbers you quote Paul are the individual generic pin codes for a 5 pin relay with changeover contacts, so not defining it. Typically though they would be cube shaped 5 pin 12 volt 40 amp mini relays with diode protection (important) available on line or at all good auto electric outlets. They are sometimes supplied with a metal mounting lug which needs to be removed. The wiper relay is a dedicated item however.
Always wise to carry a couple of replacements with you which can be quickly plugged in if only for fault finding
The five similar ones in a row are starter, fuel pump, ignition/ECU, rad fan low speed, rad fan high speed as viewed right to left.
If no dash lights with ignition on I would suspect the ignition/ECU relay. If simply starter not working then the starter relay.
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
The fuel pump one also fires up the ECU and the dash ignition etc.
Posts: 188 |
many thanks gents. It looks like its the fuel pump relay which is showing signs of corrosion. I shall change the relays over to see if it fixes it.
Posts: 327 |
It's a good idea to buy diode protected relays, I use the Durite range for quality and reliability. Ensure that you get the correct pin orientation to suit your existing sockets, oh and correct current rating of contacts, i think i used 30amp throughout to be on the safe side.
