3 members (Moggo, Grumpy2, IcePack), 352 guests, and 92 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Page 11 of 11 1 2 9 10 11
The remote greasing kit that I bought had angled grease nipples. I swapped them for straight ones which made the process a lot easier.
Costock, UK
Disco 5
Stephen
I had exactly this problem with one of the remote grease nipples on my P4 a few days ago when tidying up after our trip around N Spain. I know all the remotes work so I cleaned up and tried again and it was fine second time so definitely worth doing as suggested and try again pushing the gun on squarely. Good luck.
Regards
AlyMatt
2019 Ivory Plus4
Originally Posted by Alan Patterson
I bought one of these and a flexible hose from Machine Mart. Once it's locked on no grease escapes around the nipple.
This is the best money I've spent. Makes greasing much more simple!
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Ditto I usethem too
Well here we are! something that should be so simple but isn't! It's a bit like sharpening drills! Looks so easy when you watch someone do it but unless you're shown the tricks its impossible!
Firstly the wanner grease gun is absolute quality and I have a couple, one with a flexy coupling. for the pillars it's a flexible coupling you will need and if of the non locking variety you really do have to push and hold it in place on the nipple as you pull the trigger. It really has to be square and held in place accurately. Eventually you will feel when all is working correctly! check the blind side of the hub and pillar too as sods law says the excess grease will be pilling out there! Locking connectors are good and will probably help someone who struggles but some can be a little long and cheap ones don't last long either as they will have plastic not metal jaws! Better to learn the skill!
I so nearly fitted the remote kit but then realised I'd have to whip the wheels off to clean up after so I didn't bother!
A good tip from Nick W is just to make sure the ball in the nipple is not stuck with either old grease of by way of damage, I find just a gentle touch with an electrical srewdriver shows patency!
Are you sure you're not an AI ??🤣 .... 'patency' .... I've never heard a Human Being use that word ever, in spite of it being correct ..... remind me to post some pictures with traffic lights in them 🙂
Useful info though 👍
1 member likes this: RichardV6
Yep, I've always had problems getting grease into the front as well and bought one of the lock-on fittings, which helps. The other trick I learnt, is to use an old thin bit of cloth, like a bit of old T shirt material, which is placed over the nipple and the gun pushed onto the cloth and nipple. It seems to work quite well, try it if you are still having trouble.
