10 members (BLUE+4, Craig Jezz, CooperMan, TeddyAds, GrumpyPa, Horror, +8Rich, Joske Vermeule, Dek, Gordon D),
213
61
Topics49,860
Posts837,526
Posts: 40 |
I,m away from home with my 1984 plus 8 The indicators, fuel gauge volt gauge are dead. Have looked for loose wires and fuses ok it happened yesterday and there was a red/white wire hanging off and I reconnected it to a red/white 4 way junction which fixed it, same fault today no disconnection. Anyone got a bright idea?
G Walker 1983 +8, 1933 singer 9 2022 MG ZS (electric)
Posts: 40 |
Posts: 8,678 Likes: 491
Posts: 8,678 Likes: 491 |
If it's loose enough to come apart on it's own, when you re-connected it did you check it was 'tight' ? If you have bullet connectors these often get dirty and cause intermittent faults
Posts: 2,093 Likes: 73
Posts: 2,093 Likes: 73 |
As well as cleaning the bullet connectors, it is worth giving the female a very gentle squeeze with pliers to tighten the fit.
Posts: 40 |
thanks all, will give it a go
Posts: 8,675 Likes: 411
Posts: 8,675 Likes: 411 |
Suggest checking for power (+12 volts) from ignition switch onwards. There should be a white wire from this feeding a fuse which in turn feeds instruments either direct or via their regulator in the case of fuel and temp gauge. There is also a white/red wire from ignition switch which feeds the starter relay, live when ignition switch turned to start position. This maybe the one you mistook for red/white.
Posts: 40 |
Thanks Richard Traced voltage to fuse , it wasn't blown. Spring clips holding the fuse were slack! All working now Thanks to all repliers Lucas prince of darkness returns again. Inspecting the fuse the day before worked temporarily
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Glad you're sorted G so no need to advise. TM is brilliant, or would be if not so much drivel was posted daily.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
