6 members (Burgundymog, asbojohn, TeddyAds, BLUE+4, Ian Wegg, ScotiaSteve), 263 guests, and 45 robots.
+8Rich 82
Topics49,859
Posts837,496
Jonny72
#780493 30/06/23 05:34 PM
I,m away from home with my 1984 plus 8
The indicators, fuel gauge volt gauge are dead. Have looked for loose wires and fuses ok it happened yesterday and there was a red/white wire hanging off and I reconnected it to a red/white 4 way junction which fixed it, same fault today no disconnection.
Anyone got a bright idea?
G Walker
1983 +8, 1933 singer 9 2022 MG ZS (electric)
G Walker
If it's loose enough to come apart on it's own, when you re-connected it did you check it was 'tight' ? If you have bullet connectors these often get dirty and cause intermittent faults
As well as cleaning the bullet connectors, it is worth giving the female a very gentle squeeze with pliers to tighten the fit.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
thanks all, will give it a go
G Walker
Suggest checking for power (+12 volts) from ignition switch onwards. There should be a white wire from this feeding a fuse which in turn feeds instruments either direct or via their regulator in the case of fuel and temp gauge. There is also a white/red wire from ignition switch which feeds the starter relay, live when ignition switch turned to start position. This maybe the one you mistook for red/white.
Thanks Richard
Traced voltage to fuse , it wasn't blown. Spring clips holding the fuse were slack!
All working now
Thanks to all repliers
Lucas prince of darkness returns again.
Inspecting the fuse the day before worked temporarily
G Walker
Glad you're sorted G so no need to advise. TM is brilliant, or would be if not so much drivel was posted daily.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
