9 members (Dek, Sloany, High Hamster, Ruut Bianchi, Burgundymog, MATTMOG, John07, Rovert, sewin),
316
Topics48,341
Posts812,996
Posts: 401 Likes: 42
Posts: 401 Likes: 42 |
The thermostat on my Morgan has decided to remain closed  No wonder it was running hot! I have found a replacement on Rimmers site but I have a choice of 3. One is identified as Aftermarket for £3.78, another is OEM at £18 and a third Genuine Landrover at £22.34 Rutters have one for £16.44 Needless to say they all look the same although I am reluctant to get the cheap aftermarket one. Any thoughts?
1956 Plus 4 4 seater
Posts: 468 Likes: 52
Posts: 468 Likes: 52 |
From the perspective of operation, a wax type thermostat when it fails normally fails closed, an alcohol type thermostat usually fails open ( so they were considered the better option ). Alcohol types used to be slightly more expensive than the wax type, but wax types are more common.. That might explain cost, but it just might be a retailer milking the cost.
Posts: 7,894 Likes: 241
Posts: 7,894 Likes: 241 |
I used to drill 3 small holes in the 'stat flange to allow some 'bleed' if it failed shut, ok the engine takes a little longer to warm up but used to be a bit of a hot summer / racing failsafe
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
The one in my Plus8 had these holes in it. I took it out to flush the system when replacing the coolant. Put it back in. It is a good idea as it allows a small flow through under closed conditions.
Posts: 7,921 Likes: 217
Posts: 7,921 Likes: 217 |
A single 2mm hole in the thermostat rim positioned at the top also aids bleeding coolant after refill when thermostat otherwise closed. Some thermostats are supplied with hole in rim already and tiny split (jiggling) pin in same which aids the bleeding I'm told.
I used to drill 3 small holes in the 'stat flange to allow some 'bleed' if it failed shut, ok the engine takes a little longer to warm up but used to be a bit of a hot summer / racing failsafe The cheap one from Rimmers doesn't have any holes in flange but the other two have. I ordered the OEM one which has one hole with a split pin.
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
Make sure when you fit the thermostat you put the hole at 12 o'clock.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Make sure when you fit the thermostat you put the hole at 12 o'clock. Not heard that before, please explain.
Make sure when you fit the thermostat you put the hole at 12 o'clock. Not heard that before, please explain. Or perhaps more important ensure the drilled hole is oriented on supporting flange to be at highest point to aid self bleeding. If the thermostat flange lies in the horizontal plane it makes no difference of course.
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
12 o'clock standing where?🤔
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
