8 members (mph, MartinB60, Morganmike, DMC1904, DJC, Graham, G4FUJ, John V6, nick w), 293 guests, and 43 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,337
Members9,215
#781635 17/07/23 12:55 PM
The thermostat on my Morgan has decided to remain closed frown No wonder it was running hot!
I have found a replacement on Rimmers site but I have a choice of 3.
One is identified as Aftermarket for £3.78, another is OEM at £18 and a third Genuine Landrover at £22.34
Rutters have one for £16.44
Needless to say they all look the same although I am reluctant to get the cheap aftermarket one.
Any thoughts?
1956 Plus 4 4 seater
From the perspective of operation, a wax type thermostat when it fails normally fails closed, an alcohol type thermostat usually fails open ( so they were considered the better option ). Alcohol types used to be slightly more expensive than the wax type, but wax types are more common.. That might explain cost, but it just might be a retailer milking the cost.
Dave
Plus Six "Squeak"
Roadster departed.
I used to drill 3 small holes in the 'stat flange to allow some 'bleed' if it failed shut, ok the engine takes a little longer to warm up but used to be a bit of a hot summer / racing failsafe
The one in my Plus8 had these holes in it. I took it out to flush the system when replacing the coolant. Put it back in. It is a good idea as it allows a small flow through under closed conditions.
A single 2mm hole in the thermostat rim positioned at the top also aids bleeding coolant after refill when thermostat otherwise closed. Some thermostats are supplied with hole in rim already and tiny split (jiggling) pin in same which aids the bleeding I'm told.
The cheap one from Rimmers doesn't have any holes in flange but the other two have. I ordered the OEM one which has one hole with a split pin.
Make sure when you fit the thermostat you put the hole at 12 o'clock.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Not heard that before, please explain.
Or perhaps more important ensure the drilled hole is oriented on supporting flange to be at highest point to aid self bleeding. If the thermostat flange lies in the horizontal plane it makes no difference of course.
12 o'clock standing where?🤔
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
