9 members (Robbie, B3MOG, JMcL, gazum, +8Rich, High Hamster, Paulxj, MJF, DCH),
256
53
Topics49,863
Posts837,554
Posts: 120 |
Good morning, does have anyone have the actual dimensions for the correct balancing cones for my roadsters 16 inch wire wheels so that I can get a set machined here in Dubai to balance my wheels. Thank you
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS Triumph Thunderbird 2000 Volvo XC 60 x 3 Volvo C30
Posts: 8,678 Likes: 491
Posts: 8,678 Likes: 491 |
Another vote for the Smoothride Cones, they work well Steve, the MG owners club parts dept stock them (you don't have to be a member) and they may well be able to ship to you https://www.mgocspares.co.uk/product/w179/wire-wheel-cone-kit-42mm
Posts: 120 |
thanks guys but im looking for the actual cone dimensions, I have access to an excellent machine shop here who will make them for me at no cost.
Steve Grisdale
Posts: 375 |
Sorry but it will not be fair to provide the dimensions of the Smoothride cones against the provider. Give your spare wheel and the above sketches to your metal worker, he will be able to do the work. The diameters of the wheel balancer are standard (generaly 2 diameters). Measure them.
Regards 2005 PLUS 4
Posts: 60 Likes: 2
Posts: 60 Likes: 2 |
I just had my tires remounted and used the tire balance beads. I was worried about the stick on weights and hammer on weights. The ceramic balance beads have been fantastic and road tested up to 80/85mph... no wobbles or bounces. They compensate for variations in the suspension along with the wheel. AND NO SPECIAL CONES NEEDED! brand in my tires is called counteract. cost per tire was almost the same as traditional methods. Good thing is the beads are re-usable should you every change tires again. https://counteractbalancing.com/
^^ Good call on 'beads' I had mine re-balanced several times in the tyres lifetime because a harmonic vibration would appear occasionally, left the old weights on, pumped 4oz beads in each tyre and cured, like magic
