3 members (Saxonian, TalkMorgan, vbalddave), 157 guests, and 78 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Budster #783340 10/08/23 06:23 PM
Originally Posted by Budster
Interesting thread.
My 2003 4/4 has the Ford 1.8 ‘Black top’ Zetec engine.
The expansion tank fitted (from a MkI Ford Focus) has a lower section marked with a Min and Max level; so very easy to check levels.
Filled to the Max level would still leave 75% of the volume of the tank remaining empty, when cold.
No problems; other than the tank once leaking from a weak seam. (Local Ford dealer supplied a replacement tank for £23).
However my 4/4 suffers very slight and occasional incontinence from the bottom hose connection, to the Mulfab Al radiator.
A problem that I’ve never managed to completely solve.
Bud
4/4 - Stanley
Double jubilee clips with the tightening screw at 180 deg to each other...that'll sort it
Y
Interesting thread.
Bud
4/4 - Stanley
Tried that, improved but not fully solved the problem
Bud
Bud
4/4 "Stanley"
M500 #783357 10/08/23 07:57 PM
Have you tried the double 'wire' type hose clamps? ... the narrow round contact area can bite better than the wide, flat jubilee clip band
M500 #783358 10/08/23 08:01 PM
These sort
Interesting thread.
Bud
4/4 - Stanley
Ok, then remove hose, put a just a couple of turns of self amalgamating tape around the alloy outlet to fully cover the amount the hose pushes on, then refit with double clamps
Mikalor clamps are very good too https://www.carbuilder.com/uk/stainless-steel-exhaust-clamp-52-55-mm
M500 #783432 11/08/23 07:47 PM
It could be that your expansion tank is an aftermarket tank. As tanks are different sizes the best way to determine how much coolant is required for your car is to fill the radiator and the expansion tank run the car till the engine reaches normal running temperature turn off the engine and let the expansion tank burp out the excess fluid, this will then set the operating level.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Budster #783519 13/08/23 06:59 AM
Y
Interesting thread.
Bud
4/4 - Stanley
Bud
Suggest tightening hose clamps with small socket not just screwdriver. Be careful though its then easy to over do it. Note also rubber hoses seal better than silicone.
M500 #783533 13/08/23 09:53 AM
Formerly known as Aldermog
It could be a crack on the inside of the hose that allows fluid to wick down the reinforcing material and seep out from the end. Tightening clips will help, but only a new hose will solve the problem, I suspect.
Peter J #783618 14/08/23 10:20 AM
Peter; That’s worth checking, thanks.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
M500 #783619 14/08/23 10:28 AM
The persistent leak I had on my Roadster was because the metal pipe was not perfectly round. Even twin high pressure clamps didn't stop it, but reworking the shape, and some PTFE tape fixed it eventually.
