4 members (number thirteen, Plus Four Guy, Cat302, TrickieDickie), 323 guests, and 97 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Page 3 of 3 1 2 3
DaveW #783624 14/08/23 11:08 AM
Originally Posted by DaveW
The persistent leak I had on my Roadster was because the metal pipe was not perfectly round. Even twin high pressure clamps didn't stop it, but reworking the shape, and some PTFE tape fixed it eventually.
Thanks Dave, another idea that I can check.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
Image #783626 14/08/23 11:13 AM
Originally Posted by Image
Have you tried the double 'wire' type hose clamps? ... the narrow round contact area can bite better than the wide, flat jubilee clip band
Thanks; another good idea worth trying.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
M500 #783630 14/08/23 11:47 AM
Is there a bead on the pipe? That is the usual method to improve a seal. Push the hose on past it then clips also past it. The hose tightens over the ridge formed by the bead. It was the norm on rads we made in the factory. Brass tanks and pipes with a bead rolled in on a beading machine. Pipes then spot welded to the tank for strength using a jig to orientate correctly. Pipe expanded into the hole in the tank and high temp solder to seal.
If I remember correctly we assembled Triumph Acclaim rads that had one piece plastic ranks/pipes with a moulded bead.
One tip that might work on some pipes is to use plumbing joint olives to form a bead. If the pipe dia matches olive sizes then try it. It works in domestic plumbing compression joints so a bit of solder to locate it on a car cooling pipe that is ok to solder. A suitable adhesive should work on plastic pipes. (JB Weld or similar).
M500 #783663 14/08/23 05:28 PM
Some great ideas, which I will try and keep you posted.
Many thanks to all TMers for your suggestions.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
Page 3 of 3 1 2 3
