1 members (Stevecarr),
326
48
Posts837,276
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Advice please gents. My friend has owned his 4/4 1600 crossflow since 1969. His stainless exhaust is rattling, he thinks it's a baffle, and he's thinking easiest is to replace it. Single box system. Anyone recommend a good stainless system, or a maker? Ta everso Nick
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Custom stainless silencers made to order here. No experience of the company though.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
First I'd do the obvious and check the bobbins. They often look ok but a quick pull on the exhaust shows a failed joint between the bolt & the rubber
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Nick, where is your friend located as most of the bespoke exhaust firms prefer to pattern and part assemble on the actual car to ensure a good fit
Thanks for your replies. Good call re the bobbins but they'd given him trouble before so were checked first. He's taking the engine and gbox out to cure a slight oil leak so is hoping to buy just the parts rather than having it fitted I think. But open to all suggestions. He's in Hampshire, like me, on the Surrey border. Ta again, all contributions will be passed on to him. Nick
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Made my own out of Ebay bits: Stainless Exhaust
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Had one made up to original pattern by my local exhaust fabricator - cost was very reasonable £160 I think.
Whilst you are at it, consider redesigning the exhaust mounts, a 1969 car (assuming it has not been modified already) has a right angled bracket of mild steel with a single bolt.
The single bolt becomes loose over time and causes a nice star crack to radiate from the bolt hole!
Ideally, you will need two bolts arranged vertically to secure the bracket to the chassis and some sort of bolt plate (i.e. two bolts welded to a piece of steel strip at about 2 - 2.5 inch centres) on the inside to distribute the clamping force over the chassis rail.
Arwyn
That's exactly what Morgan eventually did Arwyn  ![[Linked Image]](https://i.imgur.com/0BviGV6.jpg)
Posts: 123 Likes: 6
Posts: 123 Likes: 6 |
If the rest of the stainless exhaust system is fine, it may be cost effective to have it cut open and baffles repaired or replaced by an exhaust specialist? My Xflow has a larger manifold and early +8 silencer, Miltek renewed the innards to help flow and noise!
Posts: 411 Likes: 9
Posts: 411 Likes: 9 |
If the rest of the stainless exhaust system is fine, it may be cost effective to have it cut open and baffles repaired or replaced by an exhaust specialist? My Xflow has a larger manifold and early +8 silencer, Miltek renewed the innards to help flow and noise!  If you are thinking of replacing because of a rattle in the baffles maybe the old hammer trick would be worth a try first? Bash a dent in the casing around where the rattle is and it will pinch the baffles and hold them tight! It's an old motorcycling trick. If it works it could save you a few bob, if you were going to replace it anyway then there is nothing to loose in trying.
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
