3 members (+8Rich, stefan s, Luddite), 269 guests, and 98 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,426
In addition to wise words above I would have all wheels off to look at the brakes. Remove rear drums and ascertain free movement of the cylinder pistons. Any corrosion on the front disks needs rubbing down. Good squirt with brake cleaner wouldn’t go amiss. Axle splines cleaned and regreased. Don’t mix the spinners - replace on the axle they came from.
Remove the tool tray and squirt the rear springs with bike chain lubricant while rear axle is hanging. Car on axle stands under chassis member just in front of rear wheels.
Light oil to both sides of the bodywork trim all round to eradicate annoying squeaks.
WD40 on anything external that moves esp door hinges, lock mechanism, filler lock, ignition key, jubilee clips, hood mechanism etc.
If the wing mirrors are the originals - bin them for some decent aftermarket mirrors.
Have fun 👍
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Originally Posted by John07
In the GDI installation the engine is vertical as opposed to the 10 deg slant that it's in in the Mx5.
Cheers
I think the same as my Frontline MGB where the engine drain plug is not at the bottom of the engine due to the engine and gearbox being 100% vertical rather than on a 10% slant like the donor MX5. While draining my oil I jack up each corner of the car, take the wheels off and clean them, that allows the oil to flow out of lots of cavities. Leave it overnight with the front passenger side jacked up so the drain plug is at the lowest possible part of the sump. Next morning put the cleaned wheel back on, put the drain plug back in, new filter and then lower the car and put oil in it. I get about 600ml more oil in the drain pan overnight.
X
X
Also a know problem are the rear brakecylinders. So open the drums and have a look at them.
Greets René
2018 plus4 (sports green)
Cheers
Are you saying that Frontline are using 10deg sumps? Cos in the UK you can get Duratec wet sumps for vertical engines. You could well have the gearbox level plug issue that we have in the Mogs..
Originally Posted by PSS
Before I make a blunder I thought I would ask in here. I have a 2015 plus 4 with the GDI engine it's only done 3700 miles and has been stood for a few years. I'd like to service it . Previous invoices show 5w/40 oil but the supplied handbook shows 5w/30. Also my local motor factors list no filters I wondered if there were any Mann or wix numbers for air oil and fuel. Lastly what spark plugs as its now 8 years old I thought it best to give it a full service and change the gearbox and diff oils at tbe same time. I'm assuming a general purpose automotive grease is ok for all the grease nipes. Many thanks in advance
Very interesting thread this as, after having my 2015 GDi serviced by the excellent Techniques in Stotfold, for the last seven years, I'm now going to be doing my own servicing, which is a bit daunting as I haven't dabbled seriously with anything mechanical for many years (although my recent purchase of the Royal Enfield has definitely piqued my interest again). Fortunately I have a great bunch of Morgan owners nearby who have a vast amount of experience of looking after Morgans that I can hopefully draw on, as well as TM etc. Good luck.
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
Perhaps the fuel tank needs to be completely emptied (may have water in it because of E10 fuel) and refilling with fresh petrol.
Cheers
The workshop in Australia bought all the parts - brakes, suspension, gearbox, engine etc. from Frontline in the UK. I am not sure what Frontline do with the cars they modify but here is my engine that certainly has a 10deg sump.
Is this the sump you are talking about? It looks nicer but I do wonder if it will clear the crossmember. https://www.raceline.co.uk/products/part_section.asp?SectionID=22&CategoryID=1
I get my GDI oil filter from BHM.
The Ford numbers shown on the filter are 2 468 342 then AA6E 6714AB. In marker pen is FFB015A
Cheers
Yes it is. I'm not sure if the GDI one is the same but it is similar. By the looks of it your gear box is at an angle.
Err, with respect RichardV6 I'm not so sure your info on the gearbox for a GDI is correct. It has the Mx5 gearbox which takes 2 litres. In the GDI installation the engine is vertical as opposed to the 10 deg slant that it's in in the Mx5. This means that the gearbox is on a slant so that the level plug is lower than it should be. In order to get 2 lt into the box you have to pick the front of the car up (quite a lot!). There is also the remote gear lever mounting, if your car has one? This has a small amount of oil in it. This is also explained in the link.
See here there is also a part2. http://www.mogmag.co.uk/rumblings-from-a-mazda-box-part-1/
Edit: I use a Mahle OC1063 oil filter in my GDI.
From looking at the gear ratios given in my handbook it refers to the Ford gearbox.
Cheers
Changed my gearbox oil today, having done almost 25k miles since last change. It looked a pretty good colour.
Having drained it with the car on a level surface, I found that by running the n/s wheels up onto a couple of lengths of 6x2, a bit more came out.
Being aware of the canted gearbox, when refilling, I jacked up the front on the middle of the cross frame as far as my jack would go and that enabled my axle stands set at 13 inches high to go under. The box then took just about all of 2 litres, with just a small bit running back out. Replaced level plug and then let the car back down to level.
Hope this is useful to others.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
