Hi Foxy, the Sealey VS820 is a great piece of kit. I had a Gunson for many years but after recommendations on this forum I changed to the Sealey and find it much better. Firstly it doesn't make your tyres go flat! You can check your connections to the reservoir are airtight at 10psi before filling the Sealey with fluid, thereby saving a drenching in DOT4. Tip in 3-4 litres of brake fluid and you can do a couple of cars, clutch and brakes without having to stop and refill the bleeder. The universal adaptor is, apparently from reviews not so good so I bought several straight connectors, VS820SA.01 @ £4.29 and fitted them to the caps I required. The quick release connection to the reservoir cap allows you to change caps easily. I gave the Gunson away to a needy friend and never looked back.
