Topics49,838
Posts837,294
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Does anyone happen to know the dimensions of the O-ring on the fuel filler cap (4/4 model year 2005)? I would like to replace/ order the O-ring and the Morgan is a bit far away from me.
Posts: 61 Likes: 7
Posts: 61 Likes: 7 |
bmgermany take a look at this thread. Not sure what sort of filler cap you have. Mine is a 2006 4/4 and I bought the ring size as shown and it’s been fine https://www.talkmorgan.com/ubbthreads.php/galleries/581614/3I ended up buying a 2 pack of these - not expensive BS232.NBR_PK2 BS232 3.53mm Section 69.44mm Bore NITRILE 70 Rubber O-Rings - Pack Size: Pack of 2 £4.14
4/4 70th Anniversary
1 member likes this:
bmgermany |
C2RM
Thank you for your help which I appreciate very much!
I have exactly the same fuel cap.
I have tried but for me as a non-native English speaker it is hard to use the right keywords for the search function - and then read many posts to find out if the info I am looking for is included.
Once again, thank you for the exact this measurements I was looking for!
Posts: 61 Likes: 7
bmgermany - I understand your difficulty. I’m a non native Morgan speaker😉. The whole thing is a mystery to me🤣
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
I think Viton might be a better choice of material for O rings in contact with fuel bmgermany take a look at this thread. Not sure what sort of filler cap you have. Mine is a 2006 4/4 and I bought the ring size as shown and it’s been fine https://www.talkmorgan.com/ubbthreads.php/galleries/581614/3I ended up buying a 2 pack of these - not expensive BS232.NBR_PK2 BS232 3.53mm Section 69.44mm Bore NITRILE 70 Rubber O-Rings - Pack Size: Pack of 2 £4.14 I think a Viton O ring would be a better choice than nitrile, with it being in contact with fuel
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
bmgermany |
Owen you are right.
I have chosen an FKM / FPM o-ring. Viton seems to be a trade name for this material.
