9 members (DCH, Steve +8, sbarracl, David Preston, Ian Wegg, John V6, MATTMOG, PaulJ, 1560),
274
44
Posts837,972
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Can you hear the fuel pump when you first turn on the ignition prior to cranking the engine? it should run for a few seconds to prime the engine.
It makes a quite distinct sound if you listen in a quiet garage.
If not it could be a failed pump or check the relevant fuse. Assuming the swapped relay was ok. It usually is the relay. It's a common problem.
If you can hear it, start looking elsewhere.
Bob
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
First of all, check whether electrical or fuel. 1. Pull off a plug lead, attach a sparking plug with its body resting on earthed metalwork. Crank engine to see if its sparking. 2. Remove air filter, and spray some easy start or even brake cleaner into the intake whilst cranking engine.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Have you tried using your spare ignition key?
Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Posts: 17 |
If you can hear it, start looking elsewhere. Can't hear anything. Looks like the fuel pump, I guess its a complete in tank unit? Thanks Gordon
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
I'd use a meter to check for good volts as close to the pump as possible before pulling things apart ... if you have volts at the last connector before the tank when you should then set to on the pump.
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
Have you checked wiring to the inertia switch.? Mine was brittle/broken connection. Used to cut out randomly. Check wiring and if necessary break and rejoin with a connector. Solved my issue.. Phil
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Have you checked the fuse? Fuse box under the dashboard if it's the same as my old '99 Zetec car
Bob
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Avoid the Lucas / Bosch ones , they disintegrate on the shelf with age. The Factory now use Chinese ones giving 100%, sorry 99% reliability but I agree with Richard the Durite ones may certainly be worth a go.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Bud 4/4 - Stanley That’s what happened to my car, no start, try the spare key (after several hours faffing about) and away it went
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 17 |
K Hi I cannot even get the connector off, its a 4 seater and there is not much room. G
