8 members (Montegue, TalkMorgan, tezzer, Graham, G4FUJ, RichardV6, CooperMan, JohnHarris, Haggispeed),
349
Posts837,983
Posts: 17 |
Hi Folks My 2001 4/4 1.8 Zetec won't start. Just wondering where the fuel pump relay is located? Thanks Gordon
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
Hi Darkstar, on my 2002 4/4 under the bonnet on top of the scuttle is an aluminium box with a flip up lid. Left to right is flasher unit, fuel pump, fuel injection and cooling fan. The last 3 are 30-85-86-87-87a. Regards.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 310 Likes: 9
These 3 were Bosch 0 332 014 112 but may have been superseded by 0986AH0602.
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Sorry but those first numbers quoted just refer to generic DC relay pin numbers. If a replacement is required look for 12 volt five pin 40 amp diode protection changeover mini relay. Avoid the cheapest chinese ones, Durite is a good brand as below. ![[Linked Image]](https://www.12voltplanet.co.uk/user/products/large/Mini-Change-Over-Relay-12V-3040A-With-Diode.png)
Posts: 17 |
Many Thanks, Flasher is Black Ford, the rest are silver Bosch 0332014112. I swapped the fuel pump relay and the cooling fan one to see if it started, it didn't.
Any suggestions, I haven't run it for a couple of months, spinning fine. Regards Gordon
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Make sure your fuel pump cut off switch hasn't activated.
Posts: 17 |
[quote=britmog]"Make sure your fuel pump cut off switch hasn't activated.["
Where will I find that?
Thanks
Gordon
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Has it been stored on a battery conditioner ? If it's stood for a couple of months and the voltage whilst cranking is low the ECU will often detect this, so it won't 'fire' but will spin over on the starter
Posts: 27,835 Likes: 759
Posts: 27,835 Likes: 759 |
Thanks
Gordon It will be on the bulkhead normally on the passenger side above the wiper motor. Press down on the rubber grommet ![[Linked Image]](https://tm-img.com/images/2023/07/26/6758841e7c345951792366c2a0ad8b8f.jpeg)
Posts: 17 |
Has it been stored on a battery conditioner ? If it's stood for a couple of months and the voltage whilst cranking is low the ECU will often detect this, so it won't 'fire' but will spin over on the starter Yes it has, whats the best approach, to this/ Charge up the batters? Regards Gordon
