7 members (+8Rich, Alan Patterson, sprinty, Ian Wegg, Plus Four Guy, CBY, dogmog),
219
50
Posts837,948
Posts: 27,831 Likes: 757
Posts: 27,831 Likes: 757 |
Do the keys have a sender built into them? My 94 4/4 didn't but my S1 roadster from 2006 did. If that bit falls out the immobiliser will not be deactivated. Try comparing the key with the spare.
Posts: 17 |
Do the keys have a sender built into them? My 94 4/4 didn't but my S1 roadster from 2006 did. If that bit falls out the immobiliser will not be deactivated. Try comparing the key with the spare. No just standard Ford keys, the immobiliser light does go out when the engine spins. Same with both keys. Does the immobiliser work on the ignition or fuel? Gordon
Sorry no idea but I would guess the ignition
Posts: 17 |
Hi Folks
So I checked the relay and the power to the fuel pump both ok. so looks like its the Fuel Pump. The fuel pump is in 2 parts, top part site under the locking ring and a seal on top of the tank. It looks like this https://www.ebay.ie/itm/202776343479?fits=Car+Make%3AFord%7CModel%3AMondeo&hash=item2f366973b7:g:7YwAAOSwYKldfH4h&amdata=enc%3AAQAIAAAA4Ewqj40EKYNsgBRByLmTjU0rVBi2C3PJ3U%2FY6bIE4TzzXnWYSvg9yqkaB6E%2BGEQ0Sysld9qXnkMsUx3tospGD06WMIfCAdiYD%2BZ9bATV624EBhG7GR0jFvBh7U%2F9ew1GajOtlTSlrzY3vR2GdDeyCoQwTetRRDWttoHViVZU5F4lBDvvJQbnuicGNFks9vTe5CNT22mets4KcQY8PiNE2D2MYVi6OdvFoP8PUvQQ8X4qjdtKSUZWDfzMR4%2FpFB05kp2eO8v9SD2hLDnHQ%2FvEFTs90FM%2BYus8rbwdNWStHsjw%7Ctkp%3ABFBMrrHjq8pi The bottom part with the pump and the sender unit seems to be attached to the bottom of the tank. Does anyone know how its attached and how to remove it?
Many thanks
Gordon PS I anyone could tell me how to attach photos I'd include them.(still getting the "its too big" message)
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Can you hear the fuel pump when you first turn on the ignition prior to cranking the engine? it should run for a few seconds to prime the engine.
It makes a quite distinct sound if you listen in a quiet garage.
If not it could be a failed pump or check the relevant fuse. Assuming the swapped relay was ok. It usually is the relay. It's a common problem.
If you can hear it, start looking elsewhere. Can't hear anything. Looks like the fuel pump, I guess its a complete in tank unit? Thanks Gordon This thread may be of interest?
Roger 2011 Plus 4
