1 members (Saxonian), 161 guests, and 88 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Whilst you are in there I would change the Gearbox fluid:
https://www.gomog.com/allmorgan/seals.htm#LT77
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
1 member likes this: David-Houston
Great point. ATF Dextron III is recommended, however following a quick Google search, that does not appear to be available anymore. Do you have any recommendations on alternatives that might be available in the US?
Thanks for your help.
David
Morgan Plus 8, 1993.
Walmart sell Valvoline Dex/Merc ATF, Advance Auto Parts sell FRAM ATF Dexron lll, Quaker State do a Dexron lll synthetic ATF, Penzoil also do a Dexron lll ATF.
Bruce
2013 M3W (Olga)
Excellent. Thanks for pointing me in the right direction. Presumably even though it’s a manual gearbox an ATF works fine.
Sincerely appreciated.
David
