Topics49,880
Posts837,769
Posts: 17 Likes: 1
Posts: 17 Likes: 1 |
That is correct. That's the way they come from the factory.. Aero Racing.
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
I suspect he's referring to the P/Steering or aircon Richard? Thanks Graham. Quite bizarre how it's dislodged a drive belt though  Interesting spec to look like Brooklands Roadster.
Posts: 28,906 Likes: 353
Posts: 28,906 Likes: 353 |
Interesting spec to look like Brooklands Roadster. I thought that, too
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
Interesting spec to look like Brooklands Roadster. I thought that, too  and me…hence my comment on the tyres.
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
It has the optional Rays alloys first seen on the AeroMax. These are 19" and take (rear) 245/35 ZR19. Some models were offered with 18" using a higher profile sidewall.
You do have to be careful with the tyre pressures.
Posts: 17 Likes: 1
Well, it was repaired and happened again, this time on the autobahn. I'm starting to wonder if that's a factory defect. The car is not modified. Exactly the same side and it seems to be exactly the same fault... experts have to evaluate this first. The prevoius problem was reparied by authorised dealer. We were lucky not to hit anything. ![[Linked Image]](https://anonymfile.com/i/lm4AlR/img-0045.jpg) ![[Linked Image]](https://anonymfile.com/i/paKelO/img-0031.jpg)
It does look awfully busy in that area as Alistair suggests. I wonder therefore if something is snagging the shock absorber. Would the dealer notice though if they haven't a car for comparison
Posts: 17 Likes: 1
Unlikley. Basically the whole part where the absorber connects to the car is gone.
Posts: 37,442 Likes: 984
Posts: 37,442 Likes: 984 |
That sounds like a close call on the Autobahn, someone was taking care of you.
Good luck with a proper repair.
Posts: 17 Likes: 1
Thank you!
Yes, thankfully, it was a slow part with 120 km/h (approximately 75 mph).
Before that, I was driving over 200 km/h (about 124 mph) on an unrestricted part. So, luckily, it happened on the "slow" part.
1 member likes this:
+8Rich |
