10 members (hugo, Sloany, DaveK, sewin, Nickplus4, linklaw, TalkMorgan, RichB, Rex_tulips, Zach), 298 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,363
Posts813,333
Members9,215
Page 3 of 5 1 2 3 4 5
Loctite 263 might be a better bet as it is virtually permanent. Don’t think you will have much room to get a nut on, and even if you do it may weaken the fixing into the top part as there are not many threads to play with.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I shall probably have to use Loctite Doug, the proximity of the bumpstop making a tack weld impossible frown
The bumpstop that I've just noticed is missing frown2
However, in my experience with thread locking adhesives making sure the threads are perfectly degreased is always the challenge.
Squirty brake cleaner or equivalent works well for thoroughly degreasing almost anything Dave.
Brake cleaner was pretty much the first thing I came to know as absolutely necessary in a workshop.
When I was at White Power in Holland for a service training course for suspension struts and motorbike forks, this was also pointed out to me again and again.
Some thinners sorted it chaps.
From this...
To this....
Rear damper reattached, the damper rod treaded back into top mount no problem, I was concerned it had pulled the threads but the threads were good, a few drops of Granville thread locker should stop it winding out again.
But with the original Bilstein bumpstop gone AWOL in the seperation incident, I'm especially proud of my Sunday home fabricated replacement woohoo
Sorted thumbs
Well done.
2025 MG ZS EV aka Trigger
Found this too....
Removed the wheel, cleaned up and de-greased the spinner, hub, & wheel splines. Re-greased with fresh grease, reassembled, tightened and all good thumbs
Checked the remaining three spinners for tightness and all good, set tyre pressures and went for a test drive. Monty is back to feeling tight as a drum and he's completely rattle free too,.
I call that a successful weekend of Morgan maintenance joy
Some time ago, one of my friends also had a noise from the rear wheel area, and it was the brake drum loose. Unlike conventional wheels which hold the drum on by virtue of the wheel nuts, with wires of course, there is no contact. So we rely on the 4 set screws and star washers. In his case, they were indeed loose, so always worth checking whenever the wheels are removed. When replacing, I always apply a drip of medium hold locktite to the threads to be on the safe side.
Doug
1958 Triton 650
Good advice Doug.
Thanks thumbs
