6 members (Ian Wegg, britmog, Bishmog, James B W, Dada, Ulfulf), 287 guests, and 39 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,395
Members9,215
Rbt Aero8, Salmon, stevends
Page 3 of 3 1 2 3
Well the deed is done the new rod is in place. It took under 2 hrs. The worst bit is trying to thread the top nut as access is difficlut. In the end I took the front damper off . I decided I didn't want to jack the car without some tension in place on the cross head.
When the car is jacked up access is easy.
I used a small camera tripod mounted on a block to rest to the underside of the lower cross head. The tripod camera screw just kissed the bar and when the bar was jacked up at the far end it showed the gap to compare to the nearest jack stand. I also compared the new side to the other & the lift was the same i.e. simultaneous at the stand & the tripod.
Whilst under there I also did the usual spanner check.
Top bodging tip
Flushed with succes I decided to paint the new rod is hammerite black before using underseal.
If your tin of Hammerite is part used & has a thick skin where is has dried beware. If the screw driver you are using to break that skin bounces off try cutting it.
Don't give it a harder thump with the screw driver as you will pierce the tin bottom & discover that a few minutes later when you see a lake of paint. It is a good job the garage tiles are black. banghead
2025 MG ZS EV aka Trigger
As this morning was dry I did a quick 5 mile test drive. The rod is intact & the car steers & brakes well in a straight line. Home just as the rain returned.
thumbs
Page 3 of 3 1 2 3
