4 members (Massi_torino, MJF, Simon, TalkMorgan), 222 guests, and 96 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,628
Moggo
I have the 'red key switch' (isolator) on the bulkhead on my '76.
Negative jump lead goes to engine mount. Positive on one terminal of the isolator switch - easier to reach than the starter.
Only have a problem on first start of the day if the car hasn't been used for a couple of days (or longer). Yes it's a poor connection somewhere in the main feed.
Next time I'm up to see a pal of mine with a ramp I'll clean all the connections...
Cheers,
Put some conductive grease on the terminals - you won't need much, I've had the same tube for nearly 20 years...
Green & Grown Up
Green & Grown Up
Hi John,
The Jump Start method you described is the one in our 2009 Roadster Handbook.
Having said that, It is not that easy to get a clean attachment on the Starter Motor terminal on our Roadster in daylight. In the dark it would be a nightmare. The plug and socket idea seems far safer.
Another R100 owner reported that when he was jump started in Dubai, using this method it fried the Engine Management Chip and the Battery. I suspect they connected the wrong leads
I would imagine an Auto electrician could rig us such a system for you.
