Posts837,961
Posts: 155 Likes: 3
Posts: 155 Likes: 3 |
Couldn't get her to fail at all today, but a set of the Durite relays ordered, and I've told her that she's on a final warning when they arrive.
IanB 2010 Two tone Roadster XK8 for sensible use.
Posts: 27,833 Likes: 758
Posts: 27,833 Likes: 758 |
Hard love is often the way as Basil Fawlty showed us
1 member likes this:
waikiore |
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Sorry to hear she’s on notice. Perhaps one more last thing? The Ford antenna modules are normally super reliable, as are the chips in the keys. The led flashing rapidly implies the immobilizer isn’t receiving the, good to go signal. The connector’s contact resistance just might be the issue. Two of the four connector wires are signals. The connector appears to be an IDC connector with tin plated contacts. Not the best combination for carrying signals in an open environment long term. Perhaps next time she fails, give the connector a little wiggle with your finger. If that works, a few makes and breaks and a squirt of switch cleaner might help. ![[Linked Image]](http://tm-img.com/images/2023/11/13/idc-con.jpeg)
Roger 2011 Plus 4
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
^ Interesting info, thanks Roger
Posts: 155 Likes: 3
Had a magnified look a the connector Rog, looks good. I'm going to eliminate the relays as a possible cause and then home in on the coil.
