6 members (JMT, CooperMan, TBM, JohnHarris, Laurens, Pundit), 226 guests, and 37 robots.
+8Rich 91
John V6 49
Posts837,979
Ian B #789878 12/11/23 09:27 PM
Ian B Offline OP
Couldn't get her to fail at all today, but a set of the Durite relays ordered,
and I've told her that she's on a final warning when they arrive.
IanB
2010 Two tone Roadster
XK8 for sensible use.
Ian B #789884 12/11/23 11:14 PM
Hard love is often the way as Basil Fawlty showed us
1 member likes this: waikiore
Ian B #789899 13/11/23 09:49 AM
Rog Offline
Sorry to hear she’s on notice. Perhaps one more last thing?
The Ford antenna modules are normally super reliable, as are the chips in the keys. The led flashing rapidly implies the immobilizer isn’t receiving the, good to go signal. The connector’s contact resistance just might be the issue. Two of the four connector wires are signals. The connector appears to be an IDC connector with tin plated contacts. Not the best combination for carrying signals in an open environment long term. Perhaps next time she fails, give the connector a little wiggle with your finger. If that works, a few makes and breaks and a squirt of switch cleaner might help.
Roger
Ian B #789920 13/11/23 05:38 PM
^ Interesting info, thanks Roger thumbs
Ian B #789959 14/11/23 12:03 AM
Ian B Offline OP
Had a magnified look a the connector Rog, looks good.
I'm going to eliminate the relays as a possible cause and
then home in on the coil.
IanB
