7 members (moggywills, Ian Wegg, Robbie, KLASG, nestor59310, JMcL, hugo),
172
63
Posts837,946
Posts: 155 Likes: 3
Posts: 155 Likes: 3 |
Wondered if anyone with a roadster (2010) had bypassed their immobiliser. I've had problems with it several times over the years. Turn the ignition on and just get a rapid flashing immobiliser light. Thought i'd solved it several times , new battery, new conditioner, connections, key etc. I rarely use the mog now because of this and think i should be getting rid.
IanB 2010 Two tone Roadster XK8 for sensible use.
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Ian, that must be annoying. I know nothing about Roadsters or how to bypass a Roadster immobiliser. However it might be worth dropping the column shroud to identify the type of immobiliser antenna ring used. If your Roadster has a Ford ECU it might use one of these Ford PATs electronic modules below. This module appears to be used across a few Ford variants that use their PATs system. It’s a potential fail point so I keep a spare ready for that day. I picked up my spare on Ebay for a tenner by searching on the part number. Good luck. ![[Linked Image]](http://tm-img.com/images/2023/11/10/PATS-ring.jpeg)
Roger 2011 Plus 4
Posts: 8,695 Likes: 414
Posts: 8,695 Likes: 414 |
Some info from Dave W thread here Ian concerning proximity of the key born passive RFID to immobiliser transponder surrounding ignition lock.
Posts: 155 Likes: 3
Thanks for the helpful replies guys, did some more investigating.today. When I first tried a start, just got the fast flashing immobiser light. Nice for it to happen in my garage rather than on a garage forecourt like the last time. After getting a screwdriver to remove the steering column cowl I tried the key again .bloody thing started no problem. Left running for 15 minutes to warm up then I went ahead and removed the cowl (The coil is the same Ford unit that you show in the photo's Rog) I tried the ignition again and got the dreaded fast flashing light. Never been this regular before. Battery fully charged, tried the coil in every position on the key barrel but no joy. Removed the under bonnet relay box cover to check that I was getting full voltage, while there I pulled the relays and refitted them to make sure they were seated properly. Tried the ignition again and it worked no problem? Couldn't get it to fail again today but determined that when working the coil can be positioned anywhere on the barrel and it still detects the key. The key is not detected by the immobiliser until turned, so you can't do the detect and 20 second key turn that some models do. Never had these problems with the hidden switch under the dash of my spitfire 50 years ago.
Posts: 27,831 Likes: 757
Posts: 27,831 Likes: 757 |
Ian, Belle my 2014 Roadster has relays that rise from the connection board. I found this out after hitting a bridge expansion joint in Holland where my indicators stopped working & the power steering stopped. I pulled over & the car then wouldn't start.
I checked the relays & pushing in the fuel pump relay (it powers the ECU) all was restored.
Relays were replaced to be safe & I now have foam on the inside of the fuse box cover to stop them coming loose.
My 2005 Roadster after a drive in heavy rain wouldn't start. The immobiliser light stayed on. Later I found out that the fuel pump relay had shorted out & that powers the ECU. No power on the ECU & the immobiliser stays on.
I hope that helps. I'm no auto electrician but it seems to work.
Posts: 152 |
Question:
when replacing the immobiliser antenna ring (as shown in Rog's picture) - does it need to be "married" with the key chip/immobilizer system? Or just "plug and play"?
No they don’t need to be married. I’ve been using one from a Mondeo in my home made ecu/chip programmer thingy. A slightly different form factor to the one we have but works fine with Morgan ecu’s. ![[Linked Image]](https://dl.dropboxusercontent.com/s/qsfttm6bkx2if18/int%20box.jpg)
Roger 2011 Plus 4
Posts: 155 Likes: 3
Hi John I would have changed the relays just to eliminate then as the cause but couldn't find them in stock on e-bay (Tyco 0-1432793-1). Is this the type you have or did you find a generic replacement.
I think that part number has been discontinued now Ian. I replaced fuel pump and ECU relays with known quality Durite 12 volt 30/40 amp diode mini changeover relays when I had an intermittent issue on my Roadster. Important they have built in quenching diode. Source below. ![[Linked Image]](https://www.12voltplanet.co.uk/user/products/large/Mini-Change-Over-Relay-12V-3040A-With-Diode.png)
