5 members (linklaw, Mike D, Robbie, Cat302, aerotaff), 227 guests, and 68 robots.
+8Rich 86
Topics49,851
Posts837,443
Page 3 of 3 1 2 3
Allon White made me a nice one, better than the ugly black plastic one.
Craig Jezz
I have a very modest and inconspicuous solution. The original shroud is gone, I love my original Momo Prototipo steering wheel and have had a slim leather cover made. It could hardly be simpler.
Originally Posted by Rog
A bit late stumbling on this but what a very nice solution Richard thumbs
Yes these factory shrouds are a tad ugly so thought it might be worth posting this 50p budget fix smile
I anguished long and hard over mine when I first got the car and how to sort it. I’m useless with leather or wood so that was ruled out. So I had a plan to print a new shroud, prep the surface and experiment with dark metallic paint finishes.
But..! All that came to an abrupt halt one day when I picked up a bit of left over edging strip trim that I had kicking around and banged it on the shroud. It insantly made the thing look much nicer. For me the problem was that crude unfinished cut edge on the cheap plastic vacuum forming. It annoyed the hell out of me. Once the edge was hidden I started to warm to it and since then it hasn’t bothered me woohoo
A very effective and aesthetically pleasing solution. The edging strip makes it complete and intentional and it repeats the theme of the steering wheel. Without this strip, the shroud looks like an old plastic part taken from the construction waste container.
A few years ago, Steve Morris told a group of us that they were looking into tooling up for a better quality column shroud, but obviously that didn't go ahead. The S1 Roadster uses a Land Rover shroud, which isn't the greatest thing, but is better looking than what came next.
This was one of the first modification I did to improve the esthetics of the ugly steering column shroud. Just shortened it to expose the whole Motolita steering boss. Then glued a front cover (splitted in two halfs, as the original shroud is) made of an old piece of printed board. Polished its copper-side. Could be also black, maybe I will spray it, a matter of taste... Later replaced the also ugly column switches. See pictures.
[quote=peterd]This was one of the first modification I did to improve the esthetics of the ugly steering column shroud. Just shortened it to expose the whole Motolita steering boss. Then glued a front cover (splitted in two halfs, as the original shroud is)
Excellent solution Peter with that front cover. Has inspired me to do mine cheers
My solution is even more low-tech (and cheap): took the shroud off and sprayed the whole thing dark brown. Took me a few minutes each layer (three of them) and the cost of a spray can. So it is still plastic and not very refined, but at least it blends nicely in with the veneer of the dash and tan leather of the seats and the interior. The stalks are still black, but what the hell... The edging strip is a good idea, though - I migth add on that, also sprayed brown.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Page 3 of 3 1 2 3
