1 members (GLLOQ), 209 guests, and 32 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
Page 3 of 6 1 2 3 4 5 6
Originally Posted By thierry242
the handling of the car was far better than before.I think this is due to the extra weight
Eat, eat, eat!!! drive
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
happy new year
This morning i made a small trip with a friend to show him the car.I was very surprised that the handling of the car was far better than before.I think this is due to the extra weight of
the passenger.When he left the car she becomes again less
confortable.So the leaf suspensions are not adapted for the 4/4 sport wich weight less than a car with the spare wheel,the bumbers,etc...
That's probably why I find my Sport so excellent. I'm the sort of chap who occasionally gets accused of eating all the pies (usually by the wife - I have to point out to her that nobody trusts a thin publican)
Giles. Mogless in Paris.
happy new year
Can anyone answer whether the rear springs on a 4/4 Sport are the same as and earlier 4/4?
My 4/4 (which admitidly is upto 30,000 miles) rides firmly, but is certaily not uncomfortable. The car has a spare wheel and full bumpers and at times the significant weight of the lovely Lady Budster's luggage on the rack.
hide
However; even unladen, I would not describe the ride as anything more than "firm"
Bud
4/4 "Stanley"
I don't know the answer to that but have to say that my 4/4 Sport seems to ride pretty well. One thing I noticed when comparing my car side by side to my friend Geomogs Plus 4 was that mine seemed to sit a tad lower.....looking at the clearance from top of tyres to wheel arch.
I find the back end rides very well - certainly very comfy after my TVR.T front end patters a bit on rough surfaces ...
i dont know for the springs but the leaf suspension has 4 leafs
instead of 5 .Normally it must be softer.
The 4/4 Sport and the Plus4 SS both have the same 4 leaf leaf springs. Both have the same code on them... MRS0003L which suggests they are identical.
Went to the Belgian dealer this morning.The right front suspension spring was blocked ,no suspension at all.They also proposed free of charge to fit adjustable koni shock dampers at the rear suspension for a test.If not ok they put the originals
back.
JJW Offline
Hi Thierry,
Did the dealer explain why is was locked? Had the same problem on my new roadster. Very hard on the front. Turned out that the bottom of the kingpins were covered in thick black undercoat. This made the front stick. Was OK after cleaning/greasing. When I mentioned it to the Dutch dealer he said another possibility is tight bushes. Aparantly the factory switched from reaming to honing the bushes? On some cars they are too tight and freeze. I also tried lower tire pressure but I find the car then "bobs" more on the tire. Problem with that is it is undampened so it easily turns in continuous nodding (when going slow) With the front suspension working good I find 1.8 gives a better ride. Cheers J
It was tight bushes .Now the direction and the front suspension
are ok.But i am still not satisfied with the rear .With the koni
in the mid position it is better when the route if flat but very
hard when the route has some irregularities.I will try the softer position to see if its better.The problem is with the
leaf spring wich is not addapted to the 4/4 sport.It is the same
than on other cars but the 4/4 sport is lighter.
