8 members (Ncik P, JohnHarris, TBM, +8Rich, Robbie, MartO, Ruut Bianchi, planenut),
275
Topics49,917
Posts838,223
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
My speedo is over reading by at least 10% which also means the recorded 2200 miles should only be 2000.
Anyone else had this and is there a remedy?
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 28,914 Likes: 354
Posts: 28,914 Likes: 354 |
Don't know about the electronic ones, but in the days of mechanical speedometers, the speed reading and mileage recorder were two separate items - so your mileometer may be correct...
Cheers,
Posts: 3,643 |
Hi Viper, I found the web site 'Morganatica' through another thread on TalkMorgan. Go to section 6, section Instrumentation. That may help.
Posts: 14,009 |
When I had my diff upgrade, Ben at Mike Duncan's showed me have to adjust the later speedos. Looked pretty straightforward apart from working out the correct value to input! Anyone know what the figures actually represent?
Posts: 3,842 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,842 Likes: 11 |
I think you'll find this is the case for most speedo's when compared to Satnav's. My guess is that this gives the car manufactures enough wriggle room if deluged by speeding claims. Image the situation if it under reported by 10%.  Somewhere on the forum ( along while ago) someone did have a fix for this as they had changed the diff and it involved resetting or selecting a value on the speedo. I cant find the post but maybe Simon can help.
Slowly going green
Thanks Guys....I'll check out section 6. Trouble is at 200mph I'm really only doing 180mph.....so annoying  I know most cars over read but I've never seen 10%. Porsche are usually spot on. I'm sure if its over reading then the milometer must be doing the same???
Actually what/where is section 6??
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Speedo cannot legally read low and has a 10%(I think) allowance for over stating speed. This is the reg for when testing a kitcar at its LVA so I assume it applies to all cars. Does the MOT include a test? I don't recall seeing one. Maybe its just a yes/no for is it working?
Posts: 3,643 |
"Actually what/where is section 6??".
Viper, Section 6 is within a wikipedia type website. Type Morganatica, in Google and then look at section 6.
Posts: 11,536 Likes: 321
Posts: 11,536 Likes: 321 |
From memory I believe the legally acceptable region for a speedo from a manufacturer is +10% (Showing 77 in a 70) and -3% (Showing 68)
Wheel and tyre combinations can cause a significant margin on this.
